Hi, since first time than i try coreelec, I have problems with the original IR remote of the tvbox Ki Pro s905, it turns out that since I press a button, until it moves, there is a delay of approximately 0.5s
This is very cumbersome because when you are writing for example with the arrows, if for example you want to go to the “S” key, you end up unwittingly in the “A” key
How can I solve it?
I have tried for example another controller like that of the xbox 360 and it works perfect, also from the mobile with the app Kore works perfect, but I do not know how to fix it.
Also say that in libreelec the command works perfectly and I have asked several colleagues and they all have the same problem with the original controller of the tvbox Ki Pro s905x
Thanks a lot
