Hi all,
I had an old s905x box lying around and I wanted to turn it into a samba server on my home LAN to replace an obsolete D-Link NAS that is stuck to smb v.1. I installed CE 9.2.8 (since it’s probably the most recent version that is compatible) on it, then enabled Samba on the CE settings page. I made sure samba.conf.sample was renamed to samba.conf in the .config folder. I left the config file as default for testing purposes.
Now the problem.
From a Windows 10 machine I can browse the shares if I type \\coreelec in the address bar. I have to do that since I cannot find it in Network Neighborhood.
On a Ubuntu 22.04.2 machine the procedure that works is slightly different. In Nautilus, I have to type smb://192.168.0.22/Downloads to access the share, only after having chosen anonymous connection.
Since I would like to mount the shares in fstab as a guest user, I tried mounting one on the command line but I am always asked for a password. None of the following worked to give me anonymous (public) access:
sudo mount -t cifs -o rw,guest //192.168.0.22/Downloads tmp
sudo mount -t cifs -o rw,guest,vers=3.0 //192.168.0.22/Downloads tmp
sudo mount -t cifs -o rw,root //192.168.0.22/Downloads tmp
I know that I am doing something wrong or misunderstanding samba but I need someone more savvy to nudge me in the right direction.
TIA
