Hi Everyone,
i am having some issue with cron jobs. i have had cron jobs set up and working fine since matrix, that pull an M3u file in the night. it has also been working fine in each release of Nexus, however, i upgraded my N2+ to boot / run CE from SSD (i have seen a MASSIVE improvement in mariadb post upgrade!)
i started from scratch with the SSD, installing everying fresh and configuring cron jobs. they all appear as exeprected when i run crontab -e, i have confrimed cron is enabled on CE settings, and have verified the files cron calls are in correct path and work as expected when i run them over ssh, but they do not seem to run on schedue and download the m3u (or maybe they do run but fail for some reason)
is there some log i can check to see if the jobs even tried to run or if they failed, and if tried and failed, with what error?
