Thank you. I opened the datasheet on the S922x - that’s exactly what it is.
Everywhere on the sites is written without sharing h265.
The question is closed.
I uploaded a H264 4K@30hz sample video Dubai.mp4 248MB,
Play with latest nightbuild(20200605) on N2, a lot skips.
General
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/mp41)
File size : 248 MiB
Duration : 2 min 6 s
Overall bit rate mode : Variable
Overall bit rate : 16.4 Mb/s
Encoded date : UTC 2015-09-16 11:11:06
Tagged date : UTC 2015-09-16 11:11:36
TIM : 00:00:00:00
TSC : 30000
TSZ : 1001
IsTruncated : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5.1
Format settings : CABAC / 3 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 98.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 29.970 (30000/1001) FPS
Minimum frame rate : 29.970 FPS
Maximum frame rate : 30.000 FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.394
Language : English
Tagged date : UTC 2015-09-16 11:11:06
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Source duration : 2 min 6 s
Bit rate mode : Variable
Bit rate : 317 kb/s
Maximum bit rate : 438 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 4.80 MiB (2%)
Source stream size : 4.80 MiB (2%)
Language : English
