Duck
7 December 2025 17:25
1
Hi, I’m new to CoreElec. I have it installed on an SD card in a Minix U8K. Everything is fine, but I can’t get the Syncthing addon to work (it seems to be running, but it doesn’t allow web access).
Following the post “Syncthing 2.x plugin broken ” ( Syncthing 2.x plugin broken ), I modified the syncthing-service file, which now looks like this:
#!/bin/sh
# SPDX-License-Identifier: GPL-2.0
# Copyright (C) 2016-present Team LibreELEC (https://libreelec.tv)
. /etc/profile
oe_setup_addon service.system.syncthing
export TZ="Europe/Madrid"
sleep 60
STNODEFAULTFOLDER="1" syncthing --home=$ADDON_HOME
--gui-address="0.0.0.0:8384"
--logflags=0
--logfile=$ADDON_HOME/syncthing.log
--no-browser
--no-restart
But web access still isn’t working. What could be wrong?
vpeter
7 December 2025 17:38
2
systemctl status service.system.syncthing.service -l
Duck
7 December 2025 17:47
3
● service.system.syncthing.service - Syncthing - Open Source Continuous File Synchronization
Loaded: loaded (/storage/.config/system.d/service.system.syncthing.service; enabled; preset: disabled)
Active: activating (start) since Sun 2025-12-07 18:46:32 CET; 21s ago
Docs: http://docs.syncthing.net/
Cntrl PID: 3280 (sh)
Tasks: 2 (limit: 7135)
Memory: 996.0K ()
CGroup: /system.slice/service.system.syncthing.service
├─3280 /bin/sh /storage/.kodi/addons/service.system.syncthing/bin/syncthing-service
└─3291 sleep 60
Dec 07 18:46:32 CoreELEC systemd[1]: Failed to start service.system.syncthing.service.
Dec 07 18:46:32 CoreELEC systemd[1]: service.system.syncthing.service: Scheduled restart job, restart counter is at 44.
Dec 07 18:46:32 CoreELEC systemd[1]: Starting service.system.syncthing.service...
vpeter
7 December 2025 18:00
4
In your start file above you are missing \ at the end of the lines for command. Check the original file.
Duck
7 December 2025 18:11
5
Solved, thank you so much for your help.
I’ve attached the file that worked in case it’s useful to anyone:
#!/bin/sh
. /etc/profile
sleep 60
STNODEFAULTFOLDER="1" syncthing --home=$ADDON_HOME \
--gui-address="0.0.0.0:8384" \
--logflags=0 \
--no-browser \
--no-restart \
vpeter
7 December 2025 18:29
6
You could probably just set timezone in service file directly with
Environment="TZ=Europe/Madrid"
The question is also why do you need to set this manually?
Duck
7 December 2025 18:33
7
Thanks, but I’m a rookie and don’t know how to do that.
But your help solved the problem, thank you.
