Good evening, I use a list iptv and the addon simple client, I have an odroid c2 and an odroid n2, lately about every 30 minutes it buffers and instead of restarting it turns off the channel and returns to the channel list, clicking on the same channel restarts another 30 minutes and so on. I wanted to know if it was possible to keep the channel active while buffering as it happened time ago with previous versions maybe working on the cache or it is a problem of the list. Thanks.
You need to ask the addon developer.
Hi, this is an answer I received.
It is because it is a low quality flow. A change has been made to the Matrix version of the addon to enable some reconnection logics for HLS flows via ffmpeg
The alternative is to find a better quality supplier.
