Hi.
I have 19.2-Matrix_rc2 (Stable) installed
after setting the archive in pvr it works
but after restart it never shows that the archive is active
settings remain, but no archive
each time the addon needs to be changed in the “catchup” options
setting the options to any and then returning to the settings that are correct,
then the archive returns,
there have been several pvr, input stream direct updates in recent weeks,
for windows and android, maybe there is something important for coreelec as well.
Edit:
I think I found a problem, I had 2 pvr where 1 worked as a radio probably collided with pvr simple, after uninstalling and rebooting coreelec the archive shows normal …
