Radxa X4 low-cost, credit card-sized Intel N100 SBC goes for $60 and up
how does this compare to say Odroid N2+ for coreelec
got this from this article
  • SoC – Intel Processor N100 quad-core processor up to 3.4 GHz (Turbo) with 6MB cache, 24EU Intel HD graphics @ 750 MHz; TDP: 6W
  • MCU – Raspberry Pi RP2040 dual-core Cortex-M0+ microcontroller with 264KB SRAM for I/O control
  • System Memory – 4GB or 8GB LPDDR5 (16GB optional, but not offered for sale yet)
  • Storage
    • M.2 M-Key socket for M.2 2230 NVMe (PCIe Gen 3.0 x4) SSD tested up to 3,400 MB/s (Read) and 3,100 MB/s (Write).
    • SPI flash for the BIOS/UEFI
    • eMMC flash footprint
  • Video Output – 2x micro HDMI 2.0 ports up to 4Kp60
  • Audio – 3.5mm headphone jack with microphone input
  • Networking
    • 2.5GbE RJ45 port with PoE support through optional PoE HAT
    • Wireless
      • WiFi 5 & BT 5 for 4GB RAM model
      • WiFi 6 & BT 5.2 for 8GB RAM or more models
  • USB
    • 3x USB 3.2 host ports (10 Gbps)
    • 1x USB 2.0 host port (480 Mbps)
  • Expansion – 40-pin GPIO header with
    • Up to 2x SPI
    • Up to 2x UART
    • Up to 2x I2C
    • Up to 16x PWM
    • Up to 8x PIO(Programmable IO)
    • 1 x 5V DC power in
    • 2 x 3.3V power pin
    • Mostly compatible with the 40-pin Raspberry Pi GPIO header
  • Misc
    • Power Button
    • BOOTSEL Button for RP2040
    • Fan Header
    • RTC Header
    • BIOS features – Auto power on, Wake-on-LAN, RTC-timed wakeup, PXE boot
  • Power Supply
    • 12V/2A (min) via USB Type-C port with PD support. 25W+ recommended when all USB 3.0 are used
    • 12V via power input header
  • Dimensions – 85 x 56x 20mm
  • Temperature Range – 0°C to 60°C
here is Radxa site
sold out on aliexpress but a partner of Radxa has the 8GB model for sale (4GB sold out as of right now), with the heatsink and shipping to UK it costs
£86 (£10 shipping)
the Soc inside it N100 is good performance upgrade compared to the ageing SOC in Odroid N2+ but I was wondering what about the GPU part of it and what downsides would it have compared to the similarly priced Odroid N2+
thanks.
Also The product page on Radxa also makes mentions of upgrade options to the 8 core variants, likely i3 N305 and the 32 EU GPU. Hope they’ll elaborate on that more soon.
anyone interested?
This is not an Amlogic product so no CE support possible.
thanks, that’s a shame, been using CE for a long time and hoping a decent chipset comes out with better performance than my ODROID N2+
search continues
Better performance for what? The s922x is a beast for CE.
It’s been tested. If you type in n100 kodi in goole it should show you kodi forum with topic about it.
You could always try Libreelec :wink:
If you want to use heavy skins or addons that load up lists from TRAKT and IMDB with like 1000 entry’s. The chipset is 5 years old, technology advances allot in 5 years
yeah I’m not in rush to buy anything. I think give it 6 months then this hardware could get into more hands.
it’s going to push AMR boxes to get cheaper I think.
they released one with N100, 8GBram, wifi6 , 64GB EMMC for £71
