Hello I am using the latest CoreElec with a radxa zero 4GB. I was wondering if there is any way to enable the power/status LED while my device is on. Seems like there is no power LED for some reason unless mine is broken?
I heard back from the radxa forum and they said “Yes, you have to patch the device tree in your system. Radxa changed the GPIO connected to the LED in rev 1.5. The gpios line should reference GPIOAO_10 instead of GPIOAO_8.”
I’m not really sure how to do that- any chance this is updated in CoreELEC 20 Nexus?
