Reboot to eMMC/NAND is missing from Estuary Skin
Noob here, so… Loaded CoreElec on thumb drive and install on 1st boot successful, but Reboot to eMMC/NAND is not available on the power options menu. Reviewed the /addons/skin.estuary/xml/DialogButtonMenu.xml file using ssh and the appropriate lines of code exist, but the option to reboot from eMMC/NAND does not present. I have not loaded an alternate skin. I installed the nightly build -
[CoreELEC-Amlogic-ng.arm-21.1.1-Omega_nightly_20241206-Generic.img.gz224.30MB2024-12-06 05:27:16] on my DUNE HD Premier 4K Pro.
There is another interesting issue where the internal SSD goes unrecognized as soon as I boot to coreelec from the thumbdrive and it has to be reformatted for the Dune Box to recognize it.
Should I try the stable build to see if this gets fixed?
I tried all possible builds (stable and nightly), never saw the button appear. There must be some kind of device-specific criteria that does not work for our models.
Looking at /usr/share/kodi/addons/skin.estuary/xml/DialogButtonMenu.xml we can see that the button will only show up if there are a /dev/system or a /dev/userdata file.
                                        <item>
                                                <label>Reboot from eMMC/NAND</label>
                                                <onclick>System.ExecWait("/usr/sbin/rebootfromnand")</onclick>
                                                <onclick>Reset()</onclick>
                                                <visible>System.PathExist("/dev/system") | System.PathExist("/dev/userdata")</visible>
                                        </item>
Apparently (latest nightly-ng here), no such files are present for me, so the condition is just plain wrong for my device or build (?).
CoreELEC:/usr/share/kodi # ls /dev/system
ls: /dev/system: No such file or directory
CoreELEC:/usr/share/kodi # ls /dev/userdata
ls: /dev/userdata: No such file or directory
Until a proper fix is done, i copied the estuary skin to ~/.kodi/addons, removed the line, bumped the skin version to an arbitrary 5.0.0 in addon.xml and voilà, the button appears !
$ cp -R /usr/share/kodi/addons/skin.estuary/ ~/.kodi/addons/skin.estuary
$ # EDIT xml/DialogButtonMenu.xml
$ grep version addon.xml | grep name
<addon id="skin.estuary" version="5.0.0" name="Estuary" provider-name="phil65, Ichabod Fletchman">
Anyone knows how to do this properly ? (i.e. match the condition or fix the condition)
see Add support for reboot to internal with Android 11/12 Add path '/dev/… · CoreELEC/xbmc@af683af · GitHub
Fix for CE22 in next nightly.
Thanks. Will this eventually get backported into ce21-ng nighlies ?
I know it is FINAL on coreelec:ce_dev_cycle [CoreELEC Wiki] but there are still some nightlies coming out, what is your maintenance policy(e.g. only backport critical fixes ?) ?
Anyone who is missing this button run in ssh terminal after reboot
dmesg | paste
and post url you get. This will tell us which partitions are needed to check.
https://paste.coreelec.org/CoupleBriefed
(this is a Homatics Box 4k Plus on Android 12)
It does thave the /dev/super file so the aforementioned patch should work (but i’m on -ng which does not include the commit)
Ah, older kernel doesn’t show partitions :frowning:
You need to run ceemmc -vx, choose single mode but don’t actually do the install (cancel it). But you will see partitions listed. Copy and paste text from console here in post.
Tried, but no joy:
Starting CoreELEC eMMC installation tool...
System is not supported as no recovery is possible: sc2_s905x4_sei_smb_280_id5!
Anyway, /dev/super is present here so the commit should work (if the skin changes are backported):
CoreELEC:~ # ls -l /dev/super
brw-rw----    1 root     disk      179,  22 Feb 27  2024 /dev/super
ls -l /dev/ | paste
https://paste.coreelec.org/InformTroop
Hello.
I own two Homatics R 4k Plus.
One on ATV14 with CoreElec NG, latest Nightly, which indeed has the option to reboot into Android.
On my second Homatics, which is on ATV 12, the latest Nightly version of CoreElec NG does not offer me the option to reboot into Android.
Here is the log (dmesg | paste) as requested before :
https://paste.coreelec.org/FanciesFeldman
And ls -l /dev/ | paste :
https://paste.coreelec.org/ConnorsFussing
It’s not a particular concern for me, but if it can help…
Thanks, pretty much the same as me.
I’m guessing that on ATV14 it has either /dev/system or /dev/userdata present ?
Note for posterity: after updating the box to android 14, it has /dev/userdata and the skin shows the button.
