i make a remote file for the u9 / u22 and my Logitech Harmony remote (harmony setup to: minix u9 “android”)
for coreelec our libreelec
it is the same on the u9 our u22 only the key back is (temporarily) not working on the u22 in android os.
working keys are:
KEY_1 to 9
KEY_VOLUMEDOWN
KEY_CHANNELDOWN
KEY_CHANNELUP
KEY_UP
KEY_DOWN
KEY_LEFT
KEY_RIGHT
KEY_ENTER
KEY_FORWARD
KEY_REWIND
KEY_FIND
KEY_HOME
KEY_PLAY
KEY_STOP
KEY_POWER
KEY_BACK
KEY_MENU
who is interested can download the file here:
https://1drv.ms/u/s!AsGbD4NPF-BLgzPNw3V8Yw9NEBAd
you need to activate ssh in corelec and instal putty on windows
setup guide in the download map
after this you can install keymap editor.
to use the keys from 1 to 9 to open windows you are use frequently.
in my case in (full screen video)
8 download subtitles windows
4 and 6 sync subtitles
7 open video settings window
on the u22 you have to set inject bl301 set minix
so it will start corelecty after you power off from coreelec.
How to use the inject_bl301 tool:
How to enable/disable:
Settings
CoreELEC
Hardware
Inject BL301 Blob
