Hi, I’m new to CoreElec as I just installed v9.2.3 a couple of hours ago on my Ugoos AM6 Plus. My remote worked perfectly with Kodi in Android but it does nothing in CoreElec.
I’m sorry to say I have very limited computer knowledge so I hope the solution is simple.
The Bose remote is not in the repository. It’s a radio remote rather than IR or Bluetooth. The biggest problem is that I bought the Bose system in 2014 so it’s rather old technology now.
As it works perfectly when logged into Android, would it not be possible to copy the relevant conf files from the Android side to an external HDD and then boot into CoreElec and copy them across?
