BOX: Yundoo Y2 (S912) 2GB/16GB - CoreELEC 9.2.0
Just installed for the first time CoreELEC 9.2.0 in my box Yundoo Y2 (S912) 2GB/16GB and the remote doesn’t work. Cannot even choose language in initial setup wizard…
Any clue how to solve it?
use a usb keyboard for the initial setup, then search the forum for remote config files.
Thanks for the tip.
Followed the instructions to configure IR remote by scan with NEC protocol but without success.
Still couldn’t get it working…
Telnet looked OK:
CoreELEC:~ # ir-keytable -a /storage/.config/rc_maps.cfg -s rc0
Old keytable cleared
Wrote 25 keycode(s) to driver
Protocols changed to nec
CoreELEC:~ # systemctl start eventlircd
CoreELEC:~ # systemctl start kodi
Have a look through this NEW Repo for Remote files (Thanks to Betatester)
I know your device is not in the repo, but perhaps you could modify one that is there.
