Greetings, I run coreelec 19.5-Matrix_rc2 on an amlogic cpu, paired with an old LG TV from 2011-2012, CEC works mostly fine in that I can move around kodi with just the tv’s remote, but that feature only lasts for as long as I don’t turn off the tv screen, when I turn the tv back on the remote stops working for kodi and I have to set it up again with the tv’s software. SOMETIMES like 10% of the time the remote will still work.
these are the logs for when I: turn tv on → setup remote → move cursor around → turn tv off → turn tv on
No device type given. Using 'recording device'
CEC Parser created - libCEC version 6.0.2
no serial port given. trying autodetect:
path: /dev/aocec
com port: AOCEC
opening a connection to the CEC adapter...
DEBUG: [ 49] Broadcast (F): osd name set to 'Broadcast'
NOTICE: [ 50] connection opened
DEBUG: [ 50] << Broadcast (F) -> TV (0): POLL
DEBUG: [ 50] processor thread started
TRAFFIC: [ 50] << f0
DEBUG: [ 81] >> POLL sent
DEBUG: [ 81] TV (0): device status changed into 'present'
DEBUG: [ 81] << requesting vendor ID of 'TV' (0)
TRAFFIC: [ 81] << f0:8c
TRAFFIC: [ 425] >> 0f:87:00:e0:91
DEBUG: [ 425] TV (0): vendor = LG (00e091)
DEBUG: [ 425] >> TV (0) -> Broadcast (F): device vendor id (87)
DEBUG: [ 426] expected response received (87: device vendor id)
DEBUG: [ 426] replacing the command handler for device 'TV' (0)
DEBUG: [ 426] TV (0): CEC version 1.3a
DEBUG: [ 426] TV (0): menu language set to 'eng'
DEBUG: [ 426] registering new CEC client - v6.0.2
DEBUG: [ 426] SetClientVersion - using client version '6.0.2'
NOTICE: [ 426] setting HDMI port to 1 on device TV (0)
DEBUG: [ 427] SetConfiguration: double tap timeout = 200ms, repeat rate = 0ms, release delay = 500ms
DEBUG: [ 427] detecting logical address for type 'recording device'
DEBUG: [ 427] trying logical address 'Recorder 1'
DEBUG: [ 427] << Recorder 1 (1) -> Recorder 1 (1): POLL
TRAFFIC: [ 427] << 11
WARNING: [ 1150] Write: write failed
TRAFFIC: [ 1150] << 11
WARNING: [ 1483] Write: write failed
DEBUG: [ 1483] >> POLL not sent
DEBUG: [ 1483] using logical address 'Recorder 1'
DEBUG: [ 1483] Recorder 1 (1): device status changed into 'handled by libCEC'
DEBUG: [ 1483] Recorder 1 (1): power status changed from 'unknown' to 'on'
DEBUG: [ 1483] Recorder 1 (1): vendor = Pulse Eight (001582)
DEBUG: [ 1483] Recorder 1 (1): CEC version 1.4
DEBUG: [ 1483] AllocateLogicalAddresses - device '0', type 'recording device', LA '1'
DEBUG: [ 1485] Recorder 1 (1): osd name set to 'CECTester'
DEBUG: [ 1485] Recorder 1 (1): menu language set to 'eng'
DEBUG: [ 1485] using auto-detected physical address 1000
DEBUG: [ 1485] Recorder 1 (1): physical address changed from ffff to 1000
DEBUG: [ 1485] << Recorder 1 (1) -> broadcast (F): physical address 1000
TRAFFIC: [ 1485] << 1f:84:10:00:01
NOTICE: [ 6639] CEC client registered: libCEC version = 6.0.2, client version = 6.0.2, firmware version = 5, logical address(es) = Recorder 1 (1) , physical address: 1.0.0.0, compiled on 2022-07-27 06:55:21 by portisch@ubuntu on Linux 5.15.0-41-generic (x86_64), features: P8_USB, DRM, P8_detect, AOCEC
DEBUG: [ 6639] Recorder 1 (1): vendor = LG (00e091)
DEBUG: [ 6639] replacing the command handler for device 'Recorder 1' (1)
DEBUG: [ 6639] Recorder 1 (1): CEC version 1.3a
DEBUG: [ 6639] << Recorder 1 (1) -> TV (0): OSD name 'CECTester'
TRAFFIC: [ 6639] << 10:47:43:45:43:54:65:73:74:65:72
DEBUG: [ 7068] << requesting power status of 'TV' (0)
TRAFFIC: [ 7068] << 10:8f
DEBUG: [ 8279] expected response not received (90: report power status)
TRAFFIC: [ 8279] << 10:8f
TRAFFIC: [ 8426] >> 01:90:01
DEBUG: [ 8426] TV (0): power status changed from 'unknown' to 'standby'
DEBUG: [ 8426] >> TV (0) -> Recorder 1 (1): report power status (90)
waiting for input
DEBUG: [ 8427] expected response received (90: report power status)
TRAFFIC: [ 10003] >> 0f:87:00:e0:91
DEBUG: [ 10003] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 10003] << 1f:87:00:e0:91
DEBUG: [ 10003] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 10284] >> 0f:87:00:e0:91
DEBUG: [ 10284] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 10284] << 1f:87:00:e0:91
DEBUG: [ 10284] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 21287] >> 01
DEBUG: [ 21287] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 21415] >> 01:8c
DEBUG: [ 21415] << Recorder 1 (1) -> TV (0): vendor id LG (e091)
TRAFFIC: [ 21416] << 1f:87:00:e0:91
DEBUG: [ 21417] >> TV (0) -> Recorder 1 (1): give device vendor id (8C)
TRAFFIC: [ 35858] >> 01:1a:01
DEBUG: [ 35859] >> Recorder 1 (1): deck status changed from 'stop' to 'LG other'
DEBUG: [ 35859] << Recorder 1 (1) -> TV (0): deck status 'LG other'
TRAFFIC: [ 35859] << 10:1b:20
DEBUG: [ 35860] >> TV (0) -> Recorder 1 (1): give deck status (1A)
TRAFFIC: [ 35994] >> 01
DEBUG: [ 35994] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 38555] >> 01:44:04
DEBUG: [ 38555] SetCurrentButton right (4) D:0ms cur:4
DEBUG: [ 38555] key pressed: right (4) current(ff) duration(0)
DEBUG: [ 38555] Changed key right (4) D:0ms cur:ff
DEBUG: [ 38555] key pressed: right (4, 0)
DEBUG: [ 38555] making Recorder 1 (1) the active source
DEBUG: [ 38555] >> TV (0) -> Recorder 1 (1): user control pressed (44)
DEBUG: [ 38555] TV (0): power status changed from 'standby' to 'in transition from standby to on'
NOTICE: [ 38555] >> source activated: Recorder 1 (1)
DEBUG: [ 38555] CheckKeypressTimeout T:1615.391
DEBUG: [ 38555] Key right: idle (duration:0) (4) timeout:31492264ms (rel:500,rep:0,prs:500,rel:0)
TRAFFIC: [ 38626] >> 01:45
DEBUG: [ 38626] key released: right (4) D:71ms
DEBUG: [ 38627] >> TV (0) -> Recorder 1 (1): user control release (45)
TRAFFIC: [ 39195] >> 01:44:04
DEBUG: [ 39195] SetCurrentButton right (4) D:0ms cur:4
DEBUG: [ 39195] key pressed: right (4) current(ff) duration(0)
DEBUG: [ 39195] Changed key right (4) D:0ms cur:ff
DEBUG: [ 39195] key pressed: right (4, 0)
DEBUG: [ 39195] CheckKeypressTimeout T:1616.031
DEBUG: [ 39195] Key right: idle (duration:0) (4) timeout:31492264ms (rel:500,rep:0,prs:500,rel:0)
DEBUG: [ 39195] >> TV (0) -> Recorder 1 (1): user control pressed (44)
DEBUG: [ 39696] CheckKeypressTimeout T:1616.532
DEBUG: [ 39696] Key unknown: idle (duration:501) (ff) timeout:532889572ms (rel:1000,rep:0,prs:0,rel:0)
TRAFFIC: [ 39704] >> 01:44:04
DEBUG: [ 39704] SetCurrentButton right (4) D:0ms cur:4
DEBUG: [ 39704] key pressed: right (4) current(ff) duration(0)
DEBUG: [ 39704] Changed key right (4) D:0ms cur:ff
DEBUG: [ 39704] key pressed: right (4, 0)
DEBUG: [ 39704] CheckKeypressTimeout T:1616.540
DEBUG: [ 39704] Key right: idle (duration:0) (4) timeout:31492264ms (rel:500,rep:0,prs:500,rel:0)
DEBUG: [ 39704] >> TV (0) -> Recorder 1 (1): user control pressed (44)
TRAFFIC: [ 39776] >> 01:45
DEBUG: [ 39776] key released: right (4) D:72ms
DEBUG: [ 39776] >> TV (0) -> Recorder 1 (1): user control release (45)
TRAFFIC: [ 40976] >> 01:45
DEBUG: [ 40976] >> TV (0) -> Recorder 1 (1): user control release (45)
TRAFFIC: [ 46596] >> 0f:36
NOTICE: [ 46596] resetting SL initialised state
DEBUG: [ 46596] Recorder 1 (1): power status changed from 'on' to 'in transition from standby to on'
DEBUG: [ 46596] TV (0): power status changed from 'in transition from standby to on' to 'standby'
DEBUG: [ 46596] >> TV (0) -> Broadcast (F): standby (36)
TRAFFIC: [ 46659] >> 0f:36
NOTICE: [ 46659] resetting SL initialised state
TRAFFIC: [ 47843] >> 0f:36
NOTICE: [ 47843] resetting SL initialised state
TRAFFIC: [ 47904] >> 0f:36
NOTICE: [ 47904] resetting SL initialised state
TRAFFIC: [ 48029] >> 0f:36
NOTICE: [ 48029] resetting SL initialised state
TRAFFIC: [ 58004] >> 0f:87:00:e0:91
DEBUG: [ 58004] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 58004] << 1f:87:00:e0:91
DEBUG: [ 58004] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 58284] >> 0f:87:00:e0:91
DEBUG: [ 58284] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 58284] << 1f:87:00:e0:91
DEBUG: [ 58285] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 65632] >> 0f:87:00:e0:91
DEBUG: [ 65632] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 65632] << 1f:87:00:e0:91
DEBUG: [ 65634] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 66213] >> 0f:87:00:e0:91
DEBUG: [ 66213] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 66213] << 1f:87:00:e0:91
DEBUG: [ 66213] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 66485] >> 01
DEBUG: [ 66485] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 67917] >> 0f:87:00:e0:91
DEBUG: [ 67917] >> TV (0) -> Broadcast (F): device vendor id (87)
DEBUG: [ 67918] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 67918] << 1f:87:00:e0:91
TRAFFIC: [ 68784] >> 01
DEBUG: [ 68784] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 75096] >> 01:89:04:00
NOTICE: [ 75096] SL initialised
TRAFFIC: [ 75096] << 10:89:05:01
DEBUG: [ 75097] >> TV (0) -> Recorder 1 (1): vendor command (89)
DEBUG: [ 75212] << Recorder 1 (1) -> TV (0): deck status 'LG other'
TRAFFIC: [ 75212] << 10:1b:20
DEBUG: [ 75338] << Recorder 1 (1) -> TV (0): in transition from standby to on
TRAFFIC: [ 75339] << 10:90:02
TRAFFIC: [ 75557] >> 01:1a:01
DEBUG: [ 75558] >> TV (0) -> Recorder 1 (1): give deck status (1A)
DEBUG: [ 75558] << Recorder 1 (1) -> TV (0): deck status 'LG other'
TRAFFIC: [ 75558] << 10:1b:20
TRAFFIC: [ 82118] >> 0f:87:00:e0:91
DEBUG: [ 82118] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 82118] << 1f:87:00:e0:91
DEBUG: [ 82119] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 82527] >> 0f:87:00:e0:91
DEBUG: [ 82527] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 82527] << 1f:87:00:e0:91
DEBUG: [ 82528] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 82806] >> 0f:87:00:e0:91
DEBUG: [ 82806] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 82806] << 1f:87:00:e0:91
DEBUG: [ 82806] >> TV (0) -> Broadcast (F): device vendor id (87)
TRAFFIC: [ 82978] >> 01
DEBUG: [ 82978] << POLL: TV (0) -> Recorder 1 (1)
TRAFFIC: [ 89788] >> 0f:36
NOTICE: [ 89788] resetting SL initialised state
DEBUG: [ 89788] >> TV (0) -> Broadcast (F): standby (36)
TRAFFIC: [ 90997] >> 0f:36
NOTICE: [ 90997] resetting SL initialised state
TRAFFIC: [ 91059] >> 0f:36
NOTICE: [ 91059] resetting SL initialised state
TRAFFIC: [ 91121] >> 0f:36
NOTICE: [ 91121] resetting SL initialised state
TRAFFIC: [ 91184] >> 0f:36
NOTICE: [ 91184] resetting SL initialised state
TRAFFIC: [ 91247] >> 0f:36
NOTICE: [ 91247] resetting SL initialised state
TRAFFIC: [ 101419] >> 0f:87:00:e0:91
DEBUG: [ 101419] << Recorder 1 (1) -> Broadcast (F): vendor id LG (e091)
TRAFFIC: [ 101419] << 1f:87:00:e0:91
DEBUG: [ 101419] >> TV (0) -> Broadcast (F): device vendor id (87)
