My device is hk1 Rbox(S905x4)
I can’t find the Option-“Sync playback to display” under Settings → Player → Videos in CoreELEC 19.5-Matrix or 20.0-Nexus or CoreELEC-Amlogic-ne.arm-20.1-Nexus_nightly_20230221-Generic.
but it works well on kodi20 within slimbox system
How to display the “Sync playback to display” Option on CE SYSTEM?
Thank you!
Apologies as I had moved the S905X4 box to production and a newer 4K TV swapping out the old S912 box.
Odd thing happened.
After days of running fine on office LCD TV moved it to production LCD TV. Worked fine yesterday.
The box was in sleep mode / shutdown when I switched to it. IE: no clock display / no video display.
I could not wake it up so powered it off and restarted it. It did not reconnect to the Gb network via DHCP. Initially It was connecting at Gb speeds to a managed Gb switch. Changed the address to a static IP and would not connect. Didn’t bother with the Wireless connections.
Replaced it last night with the old S912 (running Kodi 18.X) and will plug in the new box back to my test LCD TV (office 42" 1080) today and watch it. I have not done anything with other purchased devices and might return them due to this issue.
Adjusted the video on the new box from 4K to 1080 and the network interface came back up. Yesterday did not change the video from 4K to 1080 and could not enable the network interface. This morning changed it back to 1080 and the network interface came back up automagically. Moved it back to office LCD which is 1080 only. Video is fine. Will leave it alone for time bean.
Now thinking that it was a thermal shutdown and not sleeping as I have no power settings set.
Update looks that the nic port is toast. Starts up then disconnects. Saw temp on display go to 50 +. Odd that this is happening after running for a few days.
Build in NIC doesn’t appear to be working any more. Its been left on for days using built in NIC It all changed when connecting to other TV at 4K (worked for 1 day).
Build is current release.
CoreELEC:~ # ethtool eth0:
Settings for eth0::
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: Symmetric Receive-only
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes
Changed the Ethernet port address to static IP and the DHCP WLAN address changed to static IP.
Rebooted.
Gotta run out for now…did not come back to the network …IE: WLAN and LAN on reboot.
