freddy
24 March 2024 18:22
891
I do not have any issues with passthrough
However my set up us different than yours
Iam using Audio Optic(Toslink) cable to Meredo multi channel Sound Bar
For Audio passthrough only
For video is HDMI cable direct to TV
There are many factors in regards to Audio/Video
Passthrough.
First thing us bypass avr all together
Remove HDMI from back of reciever
Go direct t TV
See if issue exists still
Also make sure you are on Expert in Settings
Using HDMI for passthrough should look something like this
Also can use the search function
Top of page
Many threads about
Hi. Anyone can check if the device can be wake up from HDMI CEC command selecting source in the TV?
Thanks.
I replay myself.
To continue using HDMI CEC you have to “Suspend” the device instead of “Power off”.
Yesterday I received my Vontar X4 4Gb/32Gb unit.
I was doing several tests.
I leave some comments that may be useful to several users:
The CE 21 NG aarch64 nightly version works well, I expect the wifi that it is slow.
To make the Wi-Fi work at maximum speed, you must paste these files into the \storage.config\firmware\brcm folder and then restart the computer.
wifi.rar - MegaUp
After restarting it connects to 433. The transfer speed tested in iperf3 is around 27-28MB (220 Mbits/sec), enough for UHD movies. (Couldn’t this be included in the usual CE builds? )
Installation to the EMMC can be done using the CE team tool
The CE 21 NO aarch64 version nightly wifi does not work.
also experience that.
just last week moved from ng to ne (fresh install)
and with some files getting image stutters
the last video was with DD+ audio
in Audio configure pass-throw
my AVR is old and support only DD and DTS
Additional Information:
trying to play with debug and I getting in the log this lines:
2024-04-02 09:14:59.076 T:2756 debug <general>: CVideoPlayer::ProcessVideoData size:94924 dts:309.400 pts:309.600 dur:40.000ms, clock:301.096 level:96
2024-04-02 09:14:59.077 T:2756 debug <general>: CVideoPlayer::ProcessVideoData size:56384 dts:309.440 pts:309.520 dur:40.000ms, clock:301.097 level:97
2024-04-02 09:14:59.077 T:2756 debug <general>: CVideoPlayer::ProcessVideoData size:48934 dts:309.480 pts:309.480 dur:40.000ms, clock:301.097 level:97
2024-04-02 09:14:59.077 T:2756 debug <general>: CVideoPlayer::ProcessVideoData size:47491 dts:309.520 pts:309.560 dur:40.000ms, clock:301.097 level:98
2024-04-02 09:14:59.079 T:2759 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:341ms pts:301.440 Clock:301.099 Level:6
2024-04-02 09:14:59.119 T:2760 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-02 09:14:59.130 T:2759 debug <general>: CVideoPlayerVideo::OutputPicture - ttd:380ms pts:301.480 Clock:301.100 Level:6
2024-04-02 09:14:59.169 T:2760 debug <general>: CAEStreamParser::TrySyncAC3 - Unexpected stream type: 0 (wantEAC3dependent: true)
2024-04-02 09:14:59.171 T:2759 info <general>: Skipped 1 duplicate messages..
Sorry i mean CE 21-NO (new order).
But when i tested wifi didn’t work
Hello
how do we move to version 21, when version 20 is installed on emmc
Hello
when I choose manual update, in the channels, I only have access to kodi 19 and 20
7Ji:
My box finnally delivered and I soldered UART (baudrate is 921600 in case anyone else want to do this), the u-boot log, default env, dmesg and partition layout are too long so I have to paste it on my blog instead
Just to say thank you for the correct baud rate!
It also works for Amlogic S905W2 boxes. I was getting gibberish text before trying your tip.
Hello
compared to the coreelec22 announcement, this box will be able to officially go there?
Yes
amlogic S905X4 is good to go
has anyone tested nightly New Order builds with CE22 branch? I tested some time ago, about 2 months ago but wifi didn’t work.
Box is currently in the Field (Friends/Family)
Depending on age of your box/ versions of wifi/bluetooth chipset.
HK1X4
Vontar
Transpeed
There is no driver for bcm 4335 wifi in New Order kernel 5.15.119
Ethernet n Bluetooth will work.
At least they were working awhile ago before CoreELEC 22 NO
Currently box is using NE kernel 5.4.210
unai
28 June 2024 21:33
907
I bought this tv bx received yesterday. I want to use with emuelec or Corelec but temperature is 70º with cpu temp is normal?
Where can i download the dtb for emulec for this for the version 4GB 128GB version?
Follow the link
Right above your post
Is triple boot on Hk1x4 S905X4
unai
1 July 2024 20:25
909
OK for Vontar could be enough
https://discourse.coreelec.org/uploads/short-url/1OdoI7NhXHly4GM8wwPmhYEF5T2.dtb with for my Vontar Amlogic Hk1Box S905 X4, 4g 128ROM.
Wh say the roms is installed in internal memory and not in The SD?
