You obviously didn’t do something right because I have this device & I use conf
obviously I’m doing something wrong, just don’t understand what. A few months ago I had to do the same for another box, and it worked immediately. Can and may someone send me the meson file or the conf here?
I tried the x96 air, AmRemote and Meson IR, both don’t work, only the LED display works now. I do not get it.
The picture from the x96 Air remote control is the correct picture
also tried add-on: Keymap Editor. Even then, the remote control is not recognized.
Is there something wrong with device_trees?
I got a new sd card, set everything up again and used the recommended remote.conf on the other threads. Now everything is going as it should.
Glad you figured it out.
Added X99 Max (S922X) to Meson_IR
Today marks a milestone in the history of the Repository for AmRemote & Meson_IR Remote Controllers
We have been live for 6 months, have performed the 2nd quarterly maintenance cycle, populated the repository with 44 AmRemote and 49 Meson_IR remote configuration files, and had one thousand visitors.
In a short time, our repository has grown from a small collection of remote files into an alphabetically indexed Central Hub, complemented with a Library section containing instructions, how-to’s and manuals in PDF format, many with screenshots and guided walkthroughs, covering a multitude of InfraRed Remote related topics, as well as software tools for Windows, Mac and Linux to establish Secure SHell connections or to create bootable USB Flash Drives or (µ)SD Cards.
Bravo, and thank you for your devotion
Added BeeLink Mini MXIII to AmRemote
