Here is a corrected remote .hwdb file for the BT uGoos X4Q box UR01_BLE remote. This is simply an edited version of the UR01_BLE.hwdb file in the repository but with the added line KEYBOARD_KEY_c0040=c which enables the Menu button which was not working before. I tried =menu but this did not work so used the normal =c which works fine.
Yes I did use the file form the remote repo for BT for this uGoos remote but the menu button was definitely not working for me or for some friends too. Duh I have forgotten about the long push of the OK button.
Minix Neo U1.zip (5.5 MB)
Here is the remote.conf and picture for the Minix Neo U1. I have just tested this and it works great. There are various Minix devices in AmRemote folder but not the U1.
A friend of mine has given to me his Ugoos X4Q Extra with UR01 remote. Can pls someone link the conf. file for this remote? I have checked but cannot find it. Thank you for help.
I have problems with VC1 files they do not play at all. Is there something that must be done? Thank you for help and happy that we share the same device.
