Hello everyone. This is my first thread here, so please excuse any missing information. Feel free to ask me whatever is needed.
Back in 2021, I managed to install ce 9.2 on an old mxq pro 4k with s905 (1gb ram/8gb rom/100mbit lan). The device does not have a reset button, so I had to install a terminal app to its slooow android rom and run “reboot update” to make it boot from the sd card. Once it booted, I ran “installtointernal” and a few minutes later I had a fresh ce installation, which I later customised to my needs.
For reference, its device tree is
# cat /proc/device-tree/amlogic-dt-id gxb_p200_1g
the installation was done from the coreelec-arm-(version).img.gz, but I do not remember the dtb file I used. It was probably “gxbb_p200_1G_100M.dtb” and the tvbox was working properly for 2+ years.
And in 2023, when le released v11 and reintroduced support for a few old amlogic socs, I got that “shiny object syndrome” and I tried it from day 1, probably when it was on beta. Little did I know that the “installation” procedure would change the bootloader completely, making it impossible to boot from the emmc and boot only from sd or usb stick.
Since then, I tried restoring its original firmware in order to reinstall ce again, but I failed every time because the device gets disconnected in less than a second.
[ 26.557209] usb 3-2: new high-speed USB device number 2 using xhci_hcd
[ 26.695720] usb 3-2: New USB device found, idVendor=1b8e, idProduct=c003, bcdDevice= 0.07
[ 26.695739] usb 3-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 27.969026] usb 3-2: USB disconnect, device number 2
No matter the cable, the system, the usb ports or the version of amlogic burning tool I used, the result is always the same. This happens on usb1 only, as if all its other 3 ports are not working.
Is there anything I can do now? Thank you in advance.
p.s. Please excuse any delays in answering, because I am currently sick and recovery will be slow.
