The right place for the issue would be hrydgard/ppsspp, libretro/libretro-common has nothing to do with these topics.
Ok we can try older release ppsspp. I found 1. candidate if code for verification so, which was released 9 month ago and maybe is bad for us boxes. But also mayby was fixed many lines of related code in last ppsspp 1.18.1.
Ppsspp previous working version has been already identified and merged revert ppsspp · spleen1981/retroarch-kodi-addon-CoreELEC@6abfc6c · GitHub
ok, i will firstly testing when you release finalized zip and after i would update my call to issue on ppssspp github.
v1.7.3 available here or through updater.
- Update Retroarch to latest
- Update ScummVM to latest
- Revert PPSSPP to working version
- Add OpenAL support
- Add German translation, thanks to @sickdaflip
- Add graceful system reboot/shutdown
I confirm that issue with green artefacts and freezing was fixed. Also OPENAL helps. In last release increased perfomance in video scene about 5 fps compare to precedent version.
Vulkan is also supported on fbdev_mali with code from year 2017.
In time of running CE22NO with new kernel 5.15.137 i prepared also logs for retroarch in 64 environemnt.
More information is in link: Amlogic-no Discussion - #1065 by atirage21
My survey:
- vibration of joystick (Genesis P65) in udev mode is going in flycast (for me first time from using retroarch with same version of addon and devices - maybe new kernel of CE22NO have better hw support. Vibration of joystick never worked for me on CE21NG)
- midi is failed according to logs, but maybe is it issue with update libalsa
- sounds in game is going good with choosed openal or alsathread (in case of choosed e.g. clear “alsa”: sound is mute in 64bit CE22NO/ Alsa is going in CE21NG, but eat too much cpu energy) - i recommend openal as default sound output for CE21NG and CE22NO.
- libfmt.so.9 cannot open shared object file: No such file or directory for Dolphin (GC) - solution is only way it is to downgrade fmt or rebuilt fmt10 ?: libfmt.so.10.0.0 don't fit waybar: error while loading shared libraries: libfmt.so.9: cannot open shared object file: No such file or directory · Issue #2353 · Alexays/Waybar · GitHub
- Performance is now better in 64 bit CE22No than 32 bit CE21NG - it is definitively ok
I see that the MediaTek 8100 on my device is still carrying the driver version of 32.1.0 on Android14 hyperos. I don’t know the Valhall’s Mali-G610 GPU has the potential to upgrade user-space binaries driver is makes it support Vulkan1.3?![]()
And also mupen64plus was not started on CE22NO (on CE21NG was OK, on CE22NO is going only slow parallel-N64) and in logs is error:
No version number in ‘Core’ config section. Setting defaults. (in folder of config was not create .opt file for mupen64plus!)
Please check:
[Core]
# Mupen64Plus Core config parameter set version number. Please don't change this version number.
Version = 1.010000
[CoreEvents]
# Mupen64Plus CoreEvents config parameter set version number. Please don't change this version number.
Version = 1.000000
# Mupen64Plus SDL Input Plugin config parameter version number. Please don't change this version number.
version = 2.000000
[Rsp-HLE]
# Mupen64Plus RSP HLE Plugin config parameter version number
Version = 1.000000
[UI-Console]
# Mupen64Plus UI-Console config parameter set version number. Please don't change this version number.
Version = 1.000000
although EnableFBEmulation = False will cause problems in many games
After testing of Raspberry users focused on Rice, Glide64mk2, gles2n64, and GLideN64 at 1280x720, the best was gles2n64,
And mupin64plus have successor as simple64 based on vulkan (gpu with vulkan 1.1 is needed, but e.g. s922xj have only vulkan 1.0): https://simple64.github.io/
v1.7.4 available here or through updater.
- Update Retroarch to 1.20.0
- Fix missing libfmt
- Drop video playback causing freeze
Good kick-off for succes using of dolphin. In my test was usually 26-30 fps with temperature 40C on s922xj (in standard performance mode of cpu without OC and FAN). It maybe need only OC from 2,2 ghz to 2,4 ghz and sure next optimalization, but now are logs for it for future development e.g.:
retroarch__2025_04_01__08_47_16.log (62.4 KB)
[ERROR] Requesting OpenGL context, but RetroArch is compiled against OpenGLES. Cannot use HW context.
[ERROR] [Environ]: SET_HW_RENDER - Dynamic request HW context failed.
[libretro WARN] 47:54:834 VideoBackends/OGL/Render.cpp:750 W[Video]: Missing OGL Extensions: DualSourceBlend PinnedMemory GSInstancing ClipControl DepthClamp
[libretro WARN] 47:55:019 VideoCommon/AsyncShaderCompiler.cpp:125 W[Video]: Failed to initialize shader compiler worker thread.
[libretro WARN] 47:55:200 VideoCommon/ShaderCache.cpp:589 W[Video]: Approximating logic op with blending, this will produce incorrect rendering.
[libretro WARN] 47:55:309 VideoCommon/AsyncShaderCompiler.cpp:125 W[Video]: Failed to initialize shader compiler worker thread.
Next Feedback:
Parallel-n64 working well in 64 bit enviroment compare to Mupen62 with many errors: retroarch_mupen64.log (27.4 KB)
[ERROR] [Environ]: GET_VARIABLE: mupen64plus-MultiSampling - Invalid value.
[ERROR] [Environ]: GET_VARIABLE: mupen64plus-EnableN64DepthCompare - Invalid value.
[ERROR] [Environ]: GET_VARIABLE: mupen64plus-EnableShadersStorage - Invalid value.
And also there is longtime error in retroarch:
[ERROR] [MIDI]: snd_seq_open failed with error -2.
[ERROR] [MIDI]: Initialization failed.
- Regarding the opengl error in dolphin, it looks like the core is trying different gl contexts at startup, and eventually finds opengles3 working, so it should be no issue.
[INFO] [Environ]: SET_HW_RENDER, context type: gl.
[INFO] Requesting OpenGLES3 context.
[DEBUG] Reached end of SET_HW_RENDER.
[INFO] [Environ]: SET_HW_SHARED_CONTEXT.
[INFO] [Video]: Using HW render, OpenGL driver forced.
[INFO] [Video]: Using configured "gl" driver for GL HW render.
[INFO] [GL]: Found GL context: "fbdev_mali".
[INFO] [GL]: Detecting screen resolution: 1920x1080.
[INFO] [GL]: Vendor: ARM, Renderer: Mali-G52.
[INFO] [GL]: Version: OpenGL ES 3.2
For the mupen64plus error, it looks like it finds invalid values in your core options file, try to remove it or reset to defults.
The midi error log I would just ignore it, as there is no actual issue with sound or midi.
Mupen64plus is crashing also on clean install of CE22NO.
Retroarch have own library for CEC ? I have had in two last release of 64bit addon that a loading of retroarch turn off my tv. This happens me many times.
Old Mupen64plus is currently included only in Amlogic-ng release, in place of Mupen64plus_next.
In Amlogic-no release Mupen64plus_next is included. If not working I can replace with Mupen64plus as well. Can’t remember if with CE21 Mupen64plus_next was working or not. Do you have a retroarch.log of this crash on CE22?
Most probably you have the kodi setting to shutdown monitor through cec on kodi exit enabled.
The addon script bypasses this setting changing it temporarily and restoring it on exit, and it works up to CE20 at least. If doesn’t work for Amlogic-no releases, maybe something is changed in the structure of the configuration files of CE21/22, need to check.
In the meanwhile you could disable manually the setting.
Crashing of Mupen64plus was also on end of record this log: https://discourse.coreelec.org/uploads/short-url/41n3ZIb2eHjgCujhYmjNPp7rFIF.log
or here newer testing with debug info:
retroarch__2025_04_04__07_43_16.log (22.0 KB)
It is not recorded reason. Only was stopped a recording of log.
v1.7.5 available here or through updater.
- Update Retroarch to 1.21.0
- Add glcore video driver support
- Set glcore/openal as default video/audio drivers
- Fix same_cdi core
- [Amlogic-ng] add Flycast ‘xtreme’ core
- [Amlogic-no] Fix Mupenplus_next core
- [Amlogic-no] Add Mupenplus core
- [Amlogic-no] Add back Chailove core
- Update ScummVM core to latest
Glcore run good (and have potential for new cores e,g, panda3ds).
Mupenplus at CE22NO is going well. Mupenplus_next is very buggy (artefacts, dont see saved game). ParalleN64 should be rather remove due to incompatibility to glcore (in 32bit NG is crashing, and in 64 bit NO is very slow) - or it need some information about incompatibility to “glcore” and that must be change video output to older “gl”. Mupenplus working well in both architectures.
In menu of retroarch (for both 32 and 64 bit architecture) is missing button for Importing of contents in last release.
