Hello all, I recently bricked my Rocktek g2 android 12 while putting coreelec on it, just wondering if someone has a backup img of the firmware so I can use usb burner to flash android onto it, any help will be appreciated. Thanks
i don’t have Stock G2 Firmware
but you can ask support for Rocktek or you can try Firmware for Homatics ATV12
SEI804HM_firmware.12.8.7329
I tired that but its in a otg zip file I need an img to I can flash with usb burner, my recovery isnt loading for a zip file
i do that via recovery menu “apply update from udisk”
If it doesn’t show up, change the port USB
