Do you have any ideas why this dongle would fail (the dongle disconnects by itself after some time, often the led indicator remains on or turns off completely (like in this case, see last line in dmesg)
CoreELEC (official): 19.3-Matrix (Amlogic-ng.arm)
CE:~ # uname -a
Linux CE.garage 4.9.113 #1 SMP PREEMPT Sun Oct 24 21:34:02 CEST 2021 aarch64 GNU/Linux
shortened dmesg (removed duplicate messages):
[192627.043459@2] usb 1-1.4: new high-speed USB device number 13 using xhci-hcd
[192627.183178@2] usb 1-1.4: New USB device found, idVendor=148f, idProduct=5572
[192627.183181@2] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[192627.183183@2] usb 1-1.4: Product: 802.11 n WLAN
[192627.183185@2] usb 1-1.4: Manufacturer: Ralink
[192627.183187@2] usb 1-1.4: SerialNumber: 1.0
[192627.287470@2] usb 1-1.4: reset high-speed USB device number 13 using xhci-hcd
[192627.420373@2] ieee80211 phy9: rt2x00_set_rt: Info - RT chipset 5592, rev 0222 detected
[192627.430026@2] ieee80211 phy9: rt2x00_set_rf: Info - RF chipset 000f detected
[192627.430365@2] ieee80211 phy9: Selected rate control algorithm 'minstrel_ht'
[192627.432548@0] ieee80211 phy9: rt2x00lib_request_firmware: Info - Loading firmware file 'rt2870.bin'
[192627.432668@0] ieee80211 phy9: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[192627.673269@3] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[192628.028030@0] wlan0: authenticate with (deleted)
[192628.063360@0] wlan0: send auth to (deleted) (try 1/3)
[192628.069735@0] wlan0: authenticated
[192628.071633@0] wlan0: associate with (deleted) (try 1/3)
[192628.075202@0] wlan0: RX AssocResp from (deleted) (capab=0x131 status=0 aid=11)
[192628.083472@0] wlan0: associated
[192628.091328@0] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[192969.430115@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x0500 with error -110
[192969.542109@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0500 with error -110
[192974.469849@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x7010 with error -110
[192974.581838@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x7010 with error -110
[192974.693822@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x0404 with error -110
[192974.805832@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0500 with error -110
[192974.917851@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x0500 with error -110
[192975.030096@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0500 with error -110
[192975.365789@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x101c with error -110
[192975.477781@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x101c with error -110
[192980.969508@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x132c with error -110
[192981.081488@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x132c with error -110
[192981.193486@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1328 with error -110
[192981.305478@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x101c with error -110
[192981.417463@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x101c with error -110
[192987.141187@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1130 with error -110
[192987.253188@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1134 with error -110
[192987.365188@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1138 with error -110
[192987.477189@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x101c with error -110
[192987.589140@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x101c with error -110
[192988.037124@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1314 with error -110
[192988.149121@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1314 with error -110
[192988.261110@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1318 with error -110
[192988.373104@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1318 with error -110
[192988.485106@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x131c with error -110
[192988.597088@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x131c with error -110
[192988.709286@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1320 with error -110
[192988.821085@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1320 with error -110
[192988.933075@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1324 with error -110
[192989.045066@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1324 with error -110
[192989.157070@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x101c with error -110
[192989.269065@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x101c with error -110
[192993.864814@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1004 with error -110
[192993.976813@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1004 with error -110
[192994.088814@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0438 with error -110
[192994.200825@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0438 with error -110
[192994.200848@0] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 3 DMA timed out, invoke forced forced reset
[192994.312791@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1400 with error -110
[192994.424777@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1400 with error -110
[192996.328672@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1130 with error -110
[192996.440669@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1134 with error -110
[192996.552670@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1138 with error -110
[192996.664653@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x101c with error -110
[192996.776648@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x101c with error -110
[192996.888652@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x101c with error -110
[192997.224630@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1314 with error -110
[192997.336618@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1314 with error -110
[192997.448625@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1318 with error -110
[192997.560624@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1318 with error -110
[192997.672598@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x131c with error -110
[192997.784597@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x131c with error -110
[192997.896601@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1320 with error -110
[192998.008583@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1320 with error -110
[192998.120582@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1324 with error -110
[192998.232582@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1324 with error -110
[192998.344581@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0438 with error -110
[192998.456567@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0438 with error -110
[192998.456577@0] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 0 DMA timed out, invoke forced forced reset
[192998.476537@0] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset
[192998.616540@0] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 3 DMA timed out, invoke forced forced reset
[192998.868543@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1700 with error -110
[192998.980534@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x7010 with error -110
[192999.092534@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x7010 with error -110
[192999.204524@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x0404 with error -110
[193000.084488@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0438 with error -110
[193000.196487@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x0438 with error -110
[193000.196496@0] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 0 DMA timed out, invoke forced forced reset
[193000.336458@2] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 2 DMA timed out, invoke forced forced reset
[193000.476436@2] ieee80211 phy9: rt2x00usb_watchdog_tx_dma: Warning - TX queue 3 DMA timed out, invoke forced forced reset
[193000.728447@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1700 with error -110
[193001.468409@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x6884 with error -110
[193001.580389@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x6884 with error -110
[193001.692389@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x6108 with error -110
[193001.804386@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1908 with error -110
[193001.916385@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1114 with error -110
[193002.028369@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1114 with error -110
[193002.140395@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1118 with error -110
[193002.252360@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1118 with error -110
[193002.364415@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1010 with error -110
[193002.476369@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x7010 with error -110
[193002.588346@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x7010 with error -110
[193002.700335@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x0404 with error -110
[193002.812351@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x07 failed for offset 0x1404 with error -110
[193002.924337@0] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1404 with error -110
[193002.971483@2] ieee80211 phy9: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
[193002.971767@2] xhci-hcd xhci-hcd.0.auto: URB transfer length is wrong, xHC issue? req. len = 4, act. len = 4294967292
[193002.971883@2] ieee80211 phy9: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
[193003.072356@3] ieee80211 phy9: rt2x00usb_vendor_request: Error - Vendor Request 0x06 failed for offset 0x1368 with error -71
[193003.116878@2] ieee80211 phy9: rt2800usb_tx_sta_fifo_read_completed: Warning - TX status read failed -71
[193003.116989@2] usb 1-1.4: USB disconnect, device number 13
