RTL8821CU, Help, How to change invalid path?
Cannot get RTL8821CU sources : https://github.com/morrownr/8821cu-20210118/archive/a0c18978d1c9ab89f96083354f2c55cf15d483f7.tar.gz
Try later!
*********** FAILED COMMAND ***********
. “${get_handler}”
${SCRIPTS}/get “${PKG_NAME}”
${SCRIPTS}/unpack “${PKG_NAME}” “${PARENT_PKG}”
${SCRIPTS}/build “${1}” “${PARENT_PKG}”
FAILURE: scripts/install RTL8821CU:target has failed!
The following log for this failure is available:
/home/pc/EmuELEC/build.EmuELEC-Amlogic-ng.aarch64-4/.threads/logs/170.log
RTL8821CU:target seq 170 >>>
[222/627] [FAIL] install RTL8821CU:target
Close (problem solved)
