Note: No idea why this post has been flagged as “spam” or “advertisement”. If it doesn’t fit here, I’m grateful for any hint where to place it instead, thanks.
Does anyone else have issues whenever the audio part of movies is output as 44.1 kHz? I’m having dropouts every about 23 seconds. Since the AVR loses the input signal for about a second instead of just playing back silence, I suppose it’s a timing issue on HDMI/audio renderer level.
It doesn’t matter whether the track natively is sampled at 44.1 kHz or not, the output matters, hence it occurs with native tracks when using “best match” or “optimized”. The other rates such as 48 kHz, 88.2 kHz or 96 kHz (the highest, my current AVR takes with MPCM) seem to be unaffected by this bug.
Cross-checking with a Zidoo Z9X, the issue doesn’t occur within the otherwise same setup, outputting 44.1 kHz flawlessly.
Running an Ugoos AM6+ with CoreElec 21.2 Omega.
