After updating to 9.2.4 via auto-update, my TV does not discover the CEC of my device. Manually updating to 9.2.4.1 (had to disable auto update, manually re-select update channel and manually select version to apply update) did not fix that problem (This is the 9.2.4.1 arm version by the way).
CE is activated under Input/Peripherals, I tried various settings including default + reboot.
Another observation: With the 9.2.4 update, the “control via http, port 8080” setting got deactivated so controlling via app etc. did not work anymore. Re-enabling the specific setting fixed the issue though.
Does anyone have an idea on where I shall look for the issue here? Thanks in advance!
