The N2 will be faster, the VIM3L is more compact, has wifi and emmc built into the board.
Can anyone confirm that this X96 MAX 4/32gb will be capable with Corelec to play 4k HDR and hd audio passthrough/ bistream ?
Anyone? I am willing to order an x96 max with 4gb/32gb. Is it the right choice? 4k, hdr and audio bistream atmos /dtsx running CoreElec . Thank you in advance !
To this day I still donât understand why HDR10+ and DV donât work in a 905x2. According to that table it should support both dynamic range formats
DV is optional, and itâs only supported in hardware on some versions of the SoC. That said, you still need support for it in the kernel and also in the whole playback software stack - which is currently unavailable.
HDR10+ is currently not supported due to kernel limitation - at least AFAIK.
You want to tell me that there will be no HDR + and DV support in the future. Or could it be?
We canât say anything for sure right now.
I wouldnât bet on having DV though.
I can confirm the fact that VIM3L, for beginning, will not be manufactured with a Dolby Vision compatible SoC. This is the reason that I have canceled the order.
