Be sure to be able to “short” the eMMC if it does not boot anymore…
The vendor need to supply a image. How anyone will be able to recover the device without image?
yes, thats the one… they told me, that they have the image, but only for service purpose and they will not provide it to me.
Then send it back and they should recover it. But if this is the only way I would return the box and choose another one where also a image is provided.
To be honest, get one CE supported box as €112 is very expensive for such S905X3 device.
There are a lot of S905X3 4gb boxes with 100 ethernet .
Your box is not eactly high spec.
You will have to go over to Freaktab Forum and see if you can find a rom to try.
Or just tell them their piece of sh#t wont boot and make a warranty claim.
I see thy charge a premium to buy that thing with 2 years warranty.
