I have an “old” end-of-life box with CE : Beelink GT1 Ultimate. It’s working fine but I would like a new one to have CE updates.
So I bought a Tox3 box, S905X4, 4Gb, 32Gb.
I’ve installed CE on a SD-card and transfered it to the internal emmc. All working fine.
My problem is, in the graphic parameters, I select 4096x2160p (24.0) but the resolution is not applied, I go back to 1080p.
Previous configuration:
*Beelink GT1
AVR (Denon)
TV ==> 4K is OK ![]()
New configuration:
*Tox3
AVR (Denon)
TV ==> 4K impossible to set ![]()
Test configuration:
*Tox3
TV
AVR (Denon) ==> 4K is OK ![]()
*I can’t use this configuration because of DTS-HDMA audio passthrough not supported by the TV
dtb.img: sc2_s905x4_4g_1gbit
CE: 20.1-NEXUS NE
Thanks for you help ![]()
