dmesg output: paste(dot)coreelec(dot)org/AyalaNothings
What is the point of this cryptic link?
[ 17.514740] meson-i2c fe06c000.i2c: Direct firmware load for avl6261.patch failed with error -2
[ 17.514786] i2c i2c-3: dvb_meson: firmware file not found
There is no firmware, and I do not have this file. You need to search and find proper firmware that will work with this driver.
You need to install fimrware file like this: Add Firmware | LibreELEC.wiki
so basically there should be a file called /storage/.config/firmware/avl6261.patch and then do a reboot.
As a start You can try this:
https://github.com/availink/linux-firmware-availink/tree/f38a3a9b9906d192075984c7ac1100d51adf75a1/availink dvb-fe-avl62x1.fw.
It is (almost) working!
I’m very grateful for your help @rozpruwacz !
The almost is that I can only tune some channels, it seems the LNB is only working for the lower than 12000khz frequencies, and, of course, all the relevant channels are on 12130khz (Hispasat 30W).
Maybe something related to the 22khz tone?
I’ve tried setting a custom LNB setting on tvheadend (Ku 10750 / Ku 10750 High), with no success…
It may be relevant that i had the same issue under the factory Android firmware…
which firmware did You use ? taki shared the link to firmware that he used. @taki did You have the same problem ? firmware that I linked is the newer version compared to taki version. It is best to check both. or even check older version using history browser: History for availink - availink/linux-firmware-availink · GitHub and the clicking on “view code at this point”.
also please share dmesg output
I’ve just tried all the firmware versions (5 of them) with the same results.
As I (still) can’t post URL links, here goes the current dmesg in cryptic mode:
paste(dot)coreelec(dot)org/RegardsSinner
Many thanks!
Fixed, you are a member. Congrats!
These days I just read the topics and can’t do much. But with avl6261+av2018 I can catch all frequencies on Turksat 42est. I didn’t see any problems. Unfortunately, I do not have another satellite dish. I think you should check your device’s 13/18 volts. lnb power ic may be broken. Also, the driver 3.8.5 in “edisonV0_Version.zip”, which connects the tuner itself, is more modern.
If @Lithium has the same problem on stock android firmware then I would say it is a hardware problem. Either on the box side or the antenna side. If it is possible test antenna with different receiver.
@Lithium I need to test firmware file packaging into AVL6862 addon.
Please do such test:
- remove /storage/.config/firmware/avl6261.patch
- reboot
- the dvb tuner should not work at this moment
- install this addon version
AVL6862-22.0.10.4.zip (515.6 KB) - reboot
- the dvb tuner should work
after that paste here output of dmesg and ls -al /lib/firmware/avl6261.patch
Could you send me the CE NO for GTCombo? Because I don’t know how to build it, and I don’t have a Linux computer either ![]()
Try latest CE-NO nightly and latest AVL6862 nightly addon. There should be already some gtcombo support. But still there is missing dvb-t/c (currently only demod driver is available for dvb-t/c, it should be recognized by tvheadend but will not tune to any channel since the tuner driver is missing still). Also forget about the vfd, on my CE branch there are incompatible changes made to vfd driver and they will not be merged into the main CE branch since it would brake all other boxes.
hi. for my mecool m8s plus dvb s2x i prepared meson patch for LE13 dvb-0026-arm64-dts-amlogic-mecool-m8s-plus-dvbs2x-meson-demux.patch · GitHub but some changes for kernel config also is for this 1GB box necessary
linux.aarch64.conf https://drive.google.com/file/d/14FjAnOgkzzlMmrYSLjBMQctUGnf1u2qF/view?usp=drive_link,
would be nice if this stb box have support in incomming builds with dvb merged
this is CoreElec forum, with LE stuff go to LE forum, e.g. here: Official LE13 Test Images for Amlogic (Kodi-22) - Page 9 - Amlogic - LibreELEC Forum
I found this on GitHub, hopefully it will help you:
Thanks for that I have been looking for a driver for my mate stick and nice to now it will work with my 5530. I also have the GT Mate Combo with S905-Y4 I wonder if it would work with ATSC 1.0 with CoreELE?
If GPIO is not attached to dts, it gives wr error. There is no problem with dts where GPIOs are added. Can you add the correct dts to the main repository?
#include "sm1_s905x3_4g.dts"
model = "MagicSee C500 Pro";
coreelec-dt-id = "sm1_s905x3_magicsee_c500_pro_4g";
dvb-extern {
compatible = "amlogic, dvb-extern";
dev_name = "dvb-extern";
status = "okay";
fe_num = <2>;
fe0_demod = "avl6762";
fe0_i2c_adap_id = <&i2c3>;
fe0_demod_i2c_addr = <0x14>;
fe0_reset_value = <0>;
fe0_reset_gpio = <&gpio GPIOH_7 GPIO_ACTIVE_LOW>;
fe0_power_value = <0>;
fe0_power_gpios = <&gpio GPIOH_6 GPIO_ACTIVE_HIGH>;
fe0_ts_out_mode = <0>;
fe0_ts = <0>;
fe0_tuner0 = <0>;
fe1_demod = "avl6221c";
fe1_i2c_adap_id = <&i2c2>;
fe1_demod_i2c_addr = <0x14>;
fe1_reset_value = <0>;
fe1_reset_gpio = <&gpio GPIOZ_1 GPIO_ACTIVE_HIGH>;
fe1_power_value = <0>;
fe1_power_gpios = <&gpio GPIOZ_0 GPIO_ACTIVE_HIGH>;
fe1_ts = <1>;
fe1_tuner0 = <1>;
tuner_num = <2>;
tuner0_name = "mxl603";
tuner0_i2c_adap = <&i2c3>;
tuner0_i2c_addr = <0x60>;
tuner0_xtal = <1>;
tuner0_if_hz = <6>;
tuner0_if_agc = <0>;
tuner0_xtal_cap = <25>;
tuner0_if_invert = <1>;
tuner0_lt_out = <0>;
tuner0_xtal_mode = <0>;
tuner0_dual_power = <0>;
tuner1_name = "av2018";
tuner1_i2c_adap = <&i2c2>;
tuner1_i2c_addr = <0x62>;
tuner1_xtal = <27000>;
dvb-demux {
status = "okay";
ts0 = "serial";
ts0_control = <0x800>;
ts0_invert = <0x00>;
pinctrl-names = "s_ts0", "p_ts1";
pinctrl-0 = <&dvb_s_ts0_pins>;
pinctrl-1 = <&dvb_p_ts1_pins>;
&i2c2 {
status = "okay";
pinctrl-names="default";
pinctrl-0=<&i2c2_master_pins2>;
clock-frequency = <300000>;
&i2c3 {
status = "okay";
&demux {
status = "okay";
&amhdmitx {
vend_data {
vendor_name = "MS";
product_desc = "C500 Pro";
Welcome rozpruwacz
I installed version 21 on gt combo and everything works for me except vfd and t2 tuner
I need your help in identifying these two on version 21.
@MunirGh I don’t remember if tried CE21 on gtcombo. On current CE22 the VFD and DVB-T2 also does not work. If You want full support for GT Combo use my branch: GitHub - mczerski/CoreELEC at coreelec-22-gtcombo · GitHub
