i found a s905y4 device with linux4.9 os,Raxxio MAG544w3 TV Set-Top Box,here is the firmware, 544 - soft.infomir.com > stb > 544
I’m assuming you’re asking if the s905y4 can run CE-NG to be able to play DV FEL?
The amdolby_vision.c 4.9 driver doesn’t have any conditions for the S4 SOC family (SC2 is the newest). There’s likely a lot of other S4 drivers missing from the CE 4.9 source code.
Amlogic may have that necessary S4 source code privately, but CE has already moved past NG to focus on NO.
yeah,i just wanna try this,a lot of tv sticks use s905y4-k/j.
