@Portisch
Hi I managed to install your uboot for my s912 box
It works with cec standby only if I delete the /dev/env partition
But then android won’t boot from emmc.
If I don’t delete /dev/env partition android does boot but cec standby doesn’t work in coreelec.
Why would this be
Is the /dev/env partition meant to be deleted?
The partition /dev/env hold the bootloader environment. I have no idea how this will affect CEC.
Also the installtointernal method isn’t supported by CE!
I am not working active on this u-boot branch anymore as some retired person removed every information needed and I think the branch will be removed later someday. Hopefully a ready to use bl301 blob will come up for GXL. But I am not sure this can also be used for GXM.
@Portisch
Hi can you tell me what the difference between cec19 and cec3f
Is? Is it for the communication of cec? Read about it on the old thread?
