Hi guys.
I have the latest Core elec version installed and I have a problem with my Ethernet speeds.
This is my #ethtool -i eth0 output:
driver: st_gmac
version: Jan_2016
firmware-version:
expansion-rom-version:
bus-info:
supports-statistics: yes
supports-test: no
supports-eeprom-access: no
supports-register-dump: yes
supports-priv-flags: no
and this is my #ethtool eth0:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Supported FEC modes: Not reported
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Advertised FEC modes: Not reported
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Link partner advertised FEC modes: Not reported
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Transceiver: external
Auto-negotiation: on
Supports Wake-on: ug
Wake-on: d
Current message level: 0x0000003f (63)
drv probe link timer ifdown ifup
Link detected: yes
I dont really mind the slow speeds (30mb/sec) as much as that it’s not stable.
What I mean is that for the first 10 seconds of transfers files from my pc to the MINIX, the speed is high (30-35mb/sec probably of the SD card although it is rated for 80-90mb/sec speeds) after that the speed drops to 0-1.2mb/sec for a few seconds and then goes back up again.
The same motive is followed until the rest of the file is transferred, keeps going up and down.
This is a major problem when I try to watch a movie through SMB share that is a large size (50gb)… it keeps caching.
Any help is greatly appreciated.
thanks
