Hi Portisch, I don’t mix up anything.
The beauty of ceemmc is that it creates a full system backup (all Kodi data included). I have used it more than once to “jumpstart” a new box installation (more than one Ugoos in my home).
I have now found the problem.
I have two storage mounts, pointing to SMB shares on my network. Reason is, this way, access to the shares is faster (quite noticeable when scanning library for changes). I followed these instructions: Mount Network Share | LibreELEC.wiki
I had this suspicion that, since it has to deal with mounting stuff, it might mess up ceemmc. So I disabled those two mounts I had and ceemmc launched, immediately offering me Option #1 as always:
Make a copy of current CoreELEC installation on eMMC to current used SD or USB device
Luckily I remembered about this change I did (a couple of weeks ago), substituting the usual SMB sources with “local” mounted shares.
Went through the ceemmc -x process a second time, still booting into Ugoos. Should I try single boot instead?
As far as I know, single boot simply doesn’t work. You can try, hopefully there’s no harm in that.
Still hope somebody more knowledgeable than me can help you soon.
newbie here, I searched the forum but found no answer.
My setup would be: CoreELEC (Ugoos AM6B+) to AV Receiver HDMI 2.0 → 4K DV tv and SDR VPR.
I would only rip my discs in 4k HDR\DV when possibile.
I would like to get CoreELEC in 4k DV when the TV is on, and 1080p HDR->SDR when the VPR is on.
I imagine resolution changes automatically when I change the video output on the AVR, but what about tone mapping HDR to SDR? I see there is a flag in CoreELEC settings, how can I make it work only at certain conditions?
Like setting a rule where CoreELEC decide what to do with metadata: if the display is DV capable run DV; if not, tone map HDR to SDR.
Singe boot failed - still need help trying to setup dual boot, is there an alternative way if it’s an issue with ceemmc -x?
The Remote from my delivered AM6B+ isnt working only blinking red in Coreelec ng.
i installed the remote.conf and bluetooth doesnt recognize the remote.
The remote conf need for ir mode.
Have you correct remote.conf copyed to your root of the CoreElec installation?
Yes and in Bluetooth there IS the remote ugoos ur01 Not detected too
Not that I know of. But your situation is quite strange, I can’t imagine what could be the problem in your setup that stops ceemmc from doing its thing.
I got it work after some reboots the remote.conf was working and the bluetooth was working after i pressed volume + an - complete outside and not in the middle
Just checking again if anyone had any ideas on how to get dual booting working. Is it possible I just got a defective until, should I buy another?
Show the error you getting in console.
Flashback the original Android Image. Then try again.
Hi can i make a backup from my Dune homatics coreelec installation and restore the backup on my ugoos am6b+ ?
No
But you can make a copy of your Addons Folder, and then paste to
https://wiki.coreelec.org/coreelec:backup
So Yes
