Hmmmmmm
My Bad,i assumed it was dt_id /DTB specific
Never assume i guess.
Why would you want to anyway?
Hmmmmmm
I’m going to to to reload the Ugoos OS to fix the dual booting not working. Which files should I download? The full OTA or IMG File?
I just received my am6B+ and im to lazy to setup everything again.
So if i can backup my dune homatics with coreelec
And restore this on my am6B it save me a lot of time
Thank you for original post/question.!!
I make backups all the time(usually after every nightly update).I have only applied to Box was saved on.CPU,DTB is not a factor, as long as you are using same Branch of CoreELEC.
Here i go assuming again, a Backup from NE/NO,would not work/compatible with NG?
Again thx,always good to learn New Things!!
i dont know but u can try.
I still need help fixing dual boot - does anyone know if I should reload the full OTA or IMG File? I’d also be willing to pay someone if they can figure out how to get corelec installed on the internal memory.
A post was merged into an existing topic: Help, support CPM build
Use CEEMMC-Tool:
i’m sometimes getting black transparant bars above and on the bottom on the screen if i’m playing a DV movie. anyone same?
5 posts were merged into an existing topic: Help, support CPM build
Hello guys, i bought ugoos am6b+ some days ago and im really excited about this device and CE software. Thanks for anyone that made it happen.
One question if anyone can answer.
There is a recommendation to “Accelerate VC-1 - Exclude 24p”, is this recommendation still in effect or is it fixed?
Because I was watching a documentary (Planet earth) and it has a remux vc-1 1080i (interlaced) video and when I have this exlude 24p it happens at software and the playback is very choppy but when I do this on hardware accerelation it runs fine.
What should I do? What’s exactly the bug?
Thanks in advance.
I installed CoreELEC per this guide, and it’s up and running. I included the remote.conf file in the flash drive root.
This is probably a silly question, but how do I do the initial setup without pairing the remote?
It seems like to pair the remote, I need to “Go to Settings → CoreELEC Configuration → Bluetooth”
How do I go to Settings without a working remote?
Plug in a USB Keyboard.
No need to. If you placed proper remote.conf it will work with ir. I mean proper one!
I used the one linked in the guide
Edit - just noticed Windows isn’t showing file extensions on my USB drive, so it’s been named remote.conf.txt. That’ll be it.
Aha, thanks!
I’ve heard there’s DV tone-mapping options in CE-NO installations (to tone map HDR10 to Dolby Vision, for instance).
Is that something coming to CE-NG on AM6B+? For many it would make unofficial builds redundant.
CE-NG is EOL
There is no activ development
Why create something that’s not there in the first place? I understand converting say HDR10+ to DV if there’s a display support issue, but converting base HDR to dynamic is just faking it.
