SAMMIX R95S DTB modification
Hi everyone,
I have 2 sammix R95S (S905X 1GB /16GB) box running on Android 7 and 2GB of ram. The CoreELEC version is 9.2.7. I am using the DTB gxl_p212_1g. In order to support audio from toshlink I need to modify the dtb gxl_p212_1g to
audio_pin1 {
            amlogic,setmask = <0x06 0x10000000>;
            amlogic,clrmask = <0x06 0x8000000>;
            amlogic,pins = "GPIOAO_9";
            linux,phandle = <0x5d>;
            phandle = <0x5d>;
The change is amlogic,pins = “GPIOH_4”; to amlogic,pins = “GPIOAO_9”
How can contribute this change for the others to use?
Thanks!
You can create a autostart.sh like this example:
I wanted to modify the dtb (gxl_p212_1g.dtb) from CoreELEC nightly builds 9.2 and it seems that the audio_pin1 is not part of the dtb anymore. How can modify the gxl_p212_1g.dtb to support toslink with the GPIOAO_9 value?
Hi @Portisch, I am still trying to find where the spdif/toslink pins are defined in the dtb from 9.2 nightly build or 19.1? Any more hints :smile: thanks
So I think maybe this can work:
	audio_spdif_pins:audio_spdif {
		mux {
			groups = "spdif_out_ao";
			function = "spdif_out_ao";
Maybe…
So maybe:
fdtput -t s gxl_p212_1g.dtb /pinctrl@4b0/audio_spdif_out_pins/mux groups "spdif_out_ao"
fdtput -t s gxl_p212_1g.dtb /pinctrl@4b0/audio_spdif_out_pins/mux function "spdif_out_ao"
@Portisch thank you for all the help! I am learning more about device trees.
I wasn’t able to run the fdtput command directly.
dtname command returns gxl_p212_1g
fdtput -t s gxl_p212_1g.dtb /pinctrl@4b0/audio_spdif_out_pins/mux groups “spdif_out_ao”
Couldn’t open blob from ‘gxl_p212_1g.dtb’: No such file or directory
so I tried : mount -o remount,rw /flash
fdtput -t s /flash/dtb.img /pinctrl@4b0/audio_spdif_out_pins/mux groups “spdif_out_ao”
fdtput -t s /flash/dtb.img /pinctrl@4b0/audio_spdif_out_pins/mux function “spdif_out_ao”
That didn’t work. It removed the ALSA: AML-MESONAUDIO, HDMI I only had pulse: default,bluetooth Audio (PULSEAUDIO).
I modified the dtb to :
audio_spdif {
phandle = <0x8c>;
mux {
groups = “spdid_out_ao”;
function = “spdid_out_ao”;
It didn’t work, I tried the following and didn’t work either
audio_spdif {
phandle = <0x8c>;
mux {
groups = “spdid_out_ao9”;
function = “spdid_out_ao9”;
Any more hints? Specially on the No such file or directory when running fdtput?
