Script in sleep.d
For the special purpose of setting BT mode, I would need to run an sh script before sleep and after wakeup. I wanted to use the script in the .config/sleep.d directory for this, as always before. I created the script, tested its function from the ssh terminal, set the script to run status (chmod), but the script does not run either before sleep or after wakeup. Where could be the error?
Start with Running scrpt at wake - General Support - LibreELEC Forum
Thanks. I forgot that *.power is important… :roll_eyes:
