Several skins for CPM builds
How can there be further help for a prohibited build?
You need to check the first post. It’s explained there what this skins is for.
I’m currently using the Arctic Zephyr Reloaded skin from this page, did i choose the wrong one?
First line in that post gives you a link for the proper build. These skins are not for the official versions.
Yes, read once again the topic header “Several skins for CPM builds”
Alright i grabbed the (skin.cpm.estuary.A11.zip), do i just install it over the default Estuary skin? Anything to enable?
Sorry, i’m very new to kodi
It install as a separate skin, not over Estuary, so after installation you have to choose it instead of Estuary as your skin.
Ok im running the new skin now but how do i change the ui to show the same info as in this post? Like the DV Configuration, DV Levels Metadata ect
You also need to install the CPM build. By build, we mean a different Coreelec version than the official one you already have installed.
Edit: And if you do install it, you have to figure out your own problems. This is a topic for skins only.
Okay can you point me to it if possible
It’s on that github page already. Rest is up to you.
Look at your PM folder.
It many times helps to think twice :wink:
Closed
