Several skins for CPM builds
Several skins for custom builds
:white_check_mark: Features
📂 Expand
  • Buttons in Video OSD for PlayerProcessInfo and VS10 added.
  • Completely custom design for the PlayerProcessInfo with lots of technical information.
  • Display codec logos at video start, Video OSD and PlayerProcessInfo. (can be set in the settings: off, top left, top center or top right)
  • Self-designed codec logos. (professionally created with Inkscape in SVG format)
  • All Dolby and DTS lettering in the logos has been modernized.
  • All skins use the same look for the PlayerProcessInfo and codec logos.
:scroll: Changes
🗓️ 20. February 2026
  • Added Arctic Fuse 3 skin.
  • All other Skins are EOL.
:artist_palette: Skins
📂 Expand
📸 General screenshot
🎨 Arctic Fuse 3
🎨 Arctic Fuse 2 - Discontinued
🎨 Arctic Zephyr Reloaded - Discontinued
🎨 Aeon Nox: SiLVO - Discontinued
🎨 Arctic Zephyr 2 Resurrection Mod - Discontinued
🎨 Arctic Horizon 2 - Discontinued
🎨 Estuary - Discontinued
🎨 Confluence - Discontinued
🎨 Project Mayhem III HD - Discontinued
🎨 Rapier - Discontinued
🎨 Embuary - Discontinued
:inbox_tray: Download
🚀 Jamal2362 Repository
Please use this repository to install or update the skins listed above.
:link: Source URL (for the file manager):
https://ce-repo.github.io/repository.jamal2362/
:package: ZIP-Download (for manual installation):
repository.jamal2362-3.0.zip
:white_check_mark: Pros of my repository:
  • Always the latest versions of my customized skins
  • Automatic update function
  • No more manual installation of .zip files necessary
  • All changes I make to the skins are available in the repository within a few minutes.
  • Required dependencies are already included in the repository - no additional repository required!
Enjoy :hugs:
Amazing work with all the different skins. Two questions.
  1. Would you be willing to include a VS10 badge in your skins for whenever that engine is engaged? If so, maybe @frodo19 can share his logo with you, it looks just like the official VS10 logo from Dolby. I really like seeing at a glance whether content is native DV or VS10 DV with the OSD logos similar to Zidoo/Dune.
  2. Would you be willing to create a Plextuary version? It is very similar to Estuary with a few qol improvements for PM4K, and I think should be a relatively quick modification from Estuary.
Absolutely awesome :ok_hand:. Thanks @anon95383068 Great work.
I understand what you want, but that’s not planned.
It’s quite enough for me if only Dolby Vision is displayed there, whether it’s VS10 or not. Dolby Vision remains Dolby Vision at the end.
I think you should continue to use Frodo’s skin to display VS10 DV as the codec logo.
What exactly is the different between Plextuary and Estuary?
I registered to thank you for modifying horizon 2.
I noticed that on dialogplayerprocessinfo, row 587, you had SubtitilesName and it was not displaying the language, I replaced with SubtitlesLangEx.
Would you consider modifying dolby flags to display if it is a FEL title? a green dot, green line, whatever you prefer. CPM added a gold line to dolby video and audio logos when it is FEL and Atmos.
This is not planned, as this is already displayed in the PlayerProcessInfo whether it is FEL, Atmos or DTS:X etc…
Anyone can customize the skin at any time as they want it in the end. The base foundation is there.
Unfortunately, I can’t do justice to everyone because some prefer this and others that. It’s a never ending story if you go by that.
Info for others here:
Please do not make any requests regarding skins.
It comes what comes in the future.
Two more skins are planned, after that it’s over for now. I think I will finish this tomorrow.
Thanks for this. 1 issue. On Arctic Fuse 2 the badges show up at the start of the video, but they do not go away. I did not have that problem on Arctic Horizon 2.
Is the issue on my end?
Yes, the same thing happens to me with Arctic Fuse 2.
I have investigated it and could not find any incorrect implementation in the skin. It is correct that it is displayed longer than expected, but it goes away later.
It works but with a delay.
I think the heavy skin is responsible for this.
Aeon Nox: SiLVO and Nimbus added to the first post.
Gave Nimbus a try but on the main settings screen the option for CoreELEC configuration was missing and the power menu containing reboot to nand etc also missing so I went back to CPM estuary :pleading_face:
Bannedtastic would be killer too
That’s a skin to use specifically with a banned addon. No assistance provided here. Any link or mention to that skin will be erased. When will people read what’s we’ve said multiple times?
I would never have done it anyway, see post:
I ignore requests.
Thank you once again for your work.
Yesterday an update was released for the Arctic Fuse 1 Mod skin, which includes improvements to automatic trailers. After installing the CPM 11 skin, the entries that were implemented in the latest update are lost. I tried restarting Kodi, restarting CoreELEC, but the latest entries in the skin are lost. With previous updates of Arctic Fuse 1 Mod, this problem did not occur.
- Confluence added to the first post.
- Arctic Fuse 2 updated.
- Project Mayhem III HD skin (old XBMC default skin from 2005) added to the first post.
Arctic Fuse 2:
  • Last changes from the jurialmunkey repository synchronised and release updated.
Looking for help, running am6b+ with (skin.arctic.zephyr.mod.cpm_final_release21) & (CoreELEC-Amlogic-ng.arm-21.1.1-Omega-Generic.img).
Trying to get the same playback info as shown in this post, thanks.
