Shield Remote
31io5yDVdPL.AC_SS450
Anyone get the Shield remote working with Coreelec?
I added it as a bluetooth device and the navigation buttons work. The select button doesn’t work. I used Keymap Editor to map the select command to the key, although it registers the command and saves it still does not make the select command.
I was able to map the menu key to a different command which works successfully.
You need a correctly generated hwdb file, you can generate it yourself:-
https://wiki.coreelec.org/remote:rr_bluetooth
or there is a pre generated one here:-
