Hello everyone.
This little post, to tell you that I discovered CoreElec a few weeks ago.
I have been using Kodi for Android for a few years.
There with CoreElec I discovered a fast, stable and optimized system for my Amlogic S905x2 and even S905x3 boxes.
I have developed my own Skin (Aeon Miro Nox) and I would like to integrate the CoreElec configuration menu into the Kodi system menu.
I know I can launch it via the App menu. But I wanted to do something cleaner.
Do you have any information about this.
Thank you to the whole team for this fabulous system.
See you soon Roura
Just little request. I use dual boot version CE and Android. Both on eMMC. Only default skin has in Power section “Reboot to eMMC/CoreElec” option. Please include this in Your skin.
Wouldn’t it be better to get this put into the official Kodi repo?
I tried to submit my skin several times on the Kodi forum but I never got an answer.
You can see some visuals of the Krypton version here. https://forum.mpdb.tv/index.php/topic,36040.0.html
The Leia version is much more developed. Except for the English translation.
But that I can do with your help …
Repository Aeon Miro Nox For Leia
And tell me what you think
Yes indeed why not.
But I have to understand how the default Skin works
Above all, I decided to do it for myself because Aeon didn’t have enough options in my opinion.
And now that I’m on CoreElec I want to integrate it better.
If someone from the Team could give me advice it would be great.
No info about team for skinning
The way it works in Estuary is it just an icon that runs the addon service.coreelec.settings.
<item>
<label>CoreELEC</label>
<onclick>RunAddon(service.coreelec.settings)</onclick>
<icon>icons/settings/coreelec.png</icon>
<visible>System.HasAddon(service.coreelec.settings)</visible>
</item>
OK thanks adamg
My skin is online for CoreElec Menu system and the menu for Reboot to eMMC/CoreElec.
