Hello.
I’ve been using my own builds several months on my Minix U9-H with the @Portisch u-boot (without any problems). My compilation had adapted it to kodi 18.2rc1 and everything worked correctly, especially the suspend mode.
But around April 15, suspend mode fails (or at least I think). I have compiled the latest version of Coreelec-9.0 and it also fails this mode. However, if I use the nightly build by @relkai (build at the same commit), the suspend mode works again. I’ve tested several nightly builds and self-compiled version. I have done dirty updates between builds and the nightly always work, but not with self-compiled builds.
(i reset the cache and remove everything, and i build my custom builds, again, and the same, nightly works, not self build)
I’ve even tested the “testing” branch and it does not suspend.
Am i making something wrong?
Hi. Ive removed sources and resync again. Ive clean sources and i build testing branch. I cannot get to work, suspend mode doesnt work. It is posible that some ubuntu packages installed interfere with compilation? Im using 18.10
No luck.
I reinstall my Linux distro to Ubuntu 18.0.4, sync again, build testing branch and no sleep mode.
I build also last Coreelec-9.0 branch and no no sleep mode. However I installed nightly build from @relkai and sleep mode works again.
Please can anyone share my build from testing branch to check if there are some errors in my build?
I can only say, that I don’t do anything special in my builds and am also using Ubuntu Server 18.04 (only minimal packages needed for the build process installed).
