dmesg output
ifconfig output
I don’t have any Android image.
I repeated this test on different devices (using the same microSD card), and always get the same result.
I don’t see any other network issues, I have computers and phones that boot fast, all using DHCP.
And on these devices that boot slowly, I always play videos via NFS from the server, no issues at all.
After adding -d to connmand, I see this:
journalctl -t connmand |paste
I noticed a few seconds of delay every time it tries to resolve 0.pool.ntp.org, 1.pool.ntp.org, 2.pool.ntp.org and 3.pool.ntp.org.
I also see a long delay between these lines:
Sep 30 23:15:35 htpc connmand[3457]: ../src/service.c:service_append_added_foreach() new /net/connman/service/ethernet_001e064ab41a_cable
Sep 30 23:16:10 htpc connmand[3457]: ../src/dhcp.c:no_lease_cb() No lease available ipv4ll 0 client (nil)
In the end the interface is configured at 23:17:13, which is 101 seconds after starting.
I overwrote the configuration by copying /etc/connman/main.conf to /storage/.config/connman_main.conf, and commented these settings:
FallbackTimeservers
FallbackNameservers
AllowHostnameUpdates
And set:
UseGatewaysAsTimeservers = true
EnableOnlineCheck = false
This didn’t help as much as I expected. Removing /storage/.cache/connman didn’t help either.
At least I could solve the delay between the networking being configured and the UI of Kodi showing up.
Kodi was running, but trying to open non-existant library databases, such as kodi_music82, kodi_music81, etc, every time adding a 3 second delay.
This is because the server has the DBs for an older version of Kodi.
Anyway, can anyone here test in your devices to compare?
All you have to do is enable connman’s debug option:
mkdir -p /storage/.config/system.d/connman.service.d
echo -e "[Service]\nEnvironment=CONNMAN_DEBUG=-d" > /storage/.config/system.d/connman.service.d/override.conf
reboot
And of course, later you can disable connman’s debug with:
rm /storage/.config/system.d/connman.service.d/override.conf
