I’ve got my hands on an DV6067Y from SDMC, based on an S905Y2 SoC. It boots the latest 9.2.5 stable from an USB drive, which works pretty fine (although USB seems to be a bit slow). Now I’ve tried to install CE to the eMMC, which SEEMS to work at first:
ceemmc -vx
Starting CoreELEC eMMC installation tool...
System is not supported: g12a_s905y2_2g!
There is NO official support by Team CoreELEC
if you continue to run this tool!
Continue? [y]: y
eMMC size: 0x0001d2000000 [8GB]
Original partition table:
[mmcblk0p01] bootloader offset 0x000000000000, size 0x000000400000 [4 MB], unkn
[mmcblk0p02] reserved offset 0x000002400000, size 0x000004000000 [64 MB], unkn
[mmcblk0p03] cache offset 0x000006c00000, size 0x000046000000 [1120 MB], cache
[mmcblk0p04] env offset 0x00004d400000, size 0x000000800000 [8 MB], unkn
[mmcblk0p05] logo offset 0x00004e400000, size 0x000000800000 [8 MB], code
[mmcblk0p06] recovery offset 0x00004f400000, size 0x000001800000 [24 MB], code
[mmcblk0p07] misc offset 0x000051400000, size 0x000000800000 [8 MB], code
[mmcblk0p08] dtbo offset 0x000052400000, size 0x000000800000 [8 MB], code
[mmcblk0p09] cri_data offset 0x000053400000, size 0x000000800000 [8 MB], cache
[mmcblk0p10] param offset 0x000054400000, size 0x000001000000 [16 MB], cache
[mmcblk0p11] boot offset 0x000055c00000, size 0x000001000000 [16 MB], code
[mmcblk0p12] rsv offset 0x000057400000, size 0x000001000000 [16 MB], code
[mmcblk0p13] metadata offset 0x000058c00000, size 0x000001000000 [16 MB], code
[mmcblk0p14] vbmeta offset 0x00005a400000, size 0x000000200000 [2 MB], code
[mmcblk0p15] tee offset 0x00005ae00000, size 0x000002000000 [32 MB], code
[mmcblk0p16] vendor offset 0x00005d600000, size 0x000010000000 [256 MB], code
[mmcblk0p17] odm offset 0x00006de00000, size 0x000001000000 [16 MB], code
[mmcblk0p18] system offset 0x00006f600000, size 0x000050000000 [1280 MB], code
[mmcblk0p19] product offset 0x0000bfe00000, size 0x000001000000 [16 MB], code
[mmcblk0p20] data offset 0x0000c1600000, size 0x000110a00000 [4362 MB], data
No CoreELEC installation found on eMMC
Install in dual boot mode, CoreELEC and Android on eMMC
Use CoreELEC data from
Install in single boot mode, only CoreELEC on eMMC
[3] current used SD or USB device
[4] existing backup on current used SD or USB device
Please choose one option? [1/2/3/4]: 3
Free space of 'partition CE_FLASH': 512MB
Warning: Could not find 'dto' partition!
Free space of 'partition CE_STORAGE': 6844MB
New partition table:
[mmcblk0p02] env offset 0x000000400000, size 0x000000800000 [8 MB], unkn
[mmcblk0p03] misc offset 0x000000c00000, size 0x000000800000 [8 MB], code
[mmcblk0p04] logo offset 0x000001400000, size 0x000000800000 [8 MB], code
[mmcblk0p05] dtbo offset 0x000001c00000, size 0x000000800000 [8 MB], code
[mmcblk0p06] reserved offset 0x000002400000, size 0x000004000000 [64 MB], unkn
[mmcblk0p07] CE_FLASH offset 0x000006400000, size 0x000020000000 [512 MB], data
[mmcblk0p08] CE_STORAGE offset 0x000026400000, size 0x0001abc00000 [6844 MB], data
Used space of '/flash': 222MB
Used space of '/storage': 642MB
There is enough free space on eMMC for installation!
Install CoreELEC on eMMC.
Continue? [y]: y
Moved 'env' from offset 0x00004d400000, size 0x000000800000 to offset 0x000000400000
Moved 'misc' from offset 0x000051400000, size 0x000000800000 to offset 0x000000c00000
Moved 'logo' from offset 0x00004e400000, size 0x000000800000 to offset 0x000001400000
Moved 'dtbo' from offset 0x000052400000, size 0x000000800000 to offset 0x000001c00000
Starting to format the new 'CE_STORAGE' partition...
mke2fs 1.45.3 (14-Jul-2019)
Discarding device blocks: done
Creating filesystem with 1752064 4k blocks and 438048 inodes
Filesystem UUID: feb25a7f-24b2-4373-94df-5a66099ac324
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632
Allocating group tables: done
Writing inode tables: done
Creating journal (16384 blocks): done
Writing superblocks and filesystem accounting information: done
Starting to format the new 'CE_FLASH' partition...
mkfs.fat 4.1 (2017-01-24)
Stopping Kodi before start of copy process!
Starting copying of data to the eMMC!
Please do NOT interrupt this progress till it's finished!
Copy all data from '/flash' to '/media/CE_FLASH'
222.89M 100% 33.67MB/s 0:00:06 (xfr#69, to-chk=0/73)
Syncthing, please wait...
Copy all data from '/storage' to '/media/CE_STORAGE/coreelec_storage'
642.92M 99% 22.59MB/s 0:00:27 (xfr#2595, to-chk=0/3174)
Start Kodi again to have a user interface!
Success!
You can now power off the device, remove the used boot media (SD or USB) and
power on again to boot the device from eMMC!
After restarting and pulling the USB drive, the device just displays a black screen, not booting from eMMC, no error, nothing…
I noticed that if I restart and boot from USB again, ceemmc doesn’t detect a CE installation on the eMMC:
Also if I try use ceemmc twice wothout rebooting, I get the following error:
Partition '/dev/reserved' does not exist!
Failed to read original partition table!
Don’t know if that gives any clue about what’s the problem here.
Regards
Daniel
I just wanted to try eMMC because USB it’s kinda slow on this device. I don’t think there will a way to unlock the bootloader because the device is sold rebranded (MegantaTV Stick) as a Fire TV competitor by a big german telephone company/ISP.
