SoC S5 S928X
Here’s a temporary link to the needed dovi.ko
This file is only meant for the developers of CE right? Not something the users need to install somehow?
Place it in the root directory of your sdcard to make Dolby Vision work.
I can’t even get mine to boot. Does anybody know how to install via USB? And could they possibly give me some directions? I tried all the steps from the tutorial using the nightly image and got nowhere :face_with_symbols_over_mouth:
How would you rate the performance?
Thanks , working on AM8 .
I see a change in brightness when playing the file “L8 4-steps 100nits Trims P8 (881 nits).mp4” so it supports CM 4.0 and True Tv-led ?
What does the player debug output show? If it’s RGB 8-bit, I think it’s proper TV led. Also it should show Tv-Std instead of LLDV.
RGB 8BIT showed with fake tv-led also.
Use Rufus to burn the image to the SD or USB. Then copy the correct device tree file to the root folder and rename it to dtb.img
Tried that. Still the same error.
Your usb is not compatible, you have to buy another usb, for example sandisk brand is the best
It’s the best Samsung USB you can buy
HD audio passthrough not work . Hopefully the next version will be fixed
Are you on the latest Ugoos firmware (v1.3.5)
yeah, did a fresh flash before this rollercoaster started
Will X96x10 Pro (S928X-J) be supported?
Sooner or later.
Thank you for your work.Currently Ugoos AM8 works with CE with SD card.
Note:The dovi.ko file given above is placed in “storage/.config”
eMMC installation is also possible with ceemmc program.
Looks like USB boot is not 100% reliable.
GUI performance?
