I have set 4k60hz GUI, disabled GUI scalling. All media do play fine include DV.
support GUI 1080p@120hz ?
When you buy me a capable TV I can test
Hi everybody; first of all thanks for the great work of developersâŚ!
I would like to indicate that on my AM8 box the Nightly Build works great when installed from an SD card; Reboot to LibreELEC started with app, DV also works correctly (LG G2)
However, the Ugoos BT remote control does not work after connecting - it disconnects almost immediately; It works fine with a 3rd party remote control!
There is a new firmware for Ugoos AM8 - 1.3.7
If I install it, it wonât cause problems under CEâŚ?
This DoVi.ko allows for 8.1 profile conversion and other DV profiles, not for FEL obtained on the AM6B+, correct?
Thatâs right - no DV FEL
Where did you find the 1.3.7 firmware??
You can do it with online update
Automatic firmware update
Changelog:
- Added new power indicator modes
- Added setting for change number of volume regulator steps
- Audio decoders improvements
- Some improvements to high-resolution audio playback
- Fixed some IEC audio passthrough streams
- TrueHD audio passthrough improvements
- Added support for some TrueHD streams in native video players
- Added transcoding of TrueHD pass-through audio streams to AC3 for S/PDIF
- Fixed support of some DTS-HD audio tracks
- Added support for DTS-HD audio passthrough in native video players
- Now S/PDIF plays DTS core from DTS-HD audio passthrough stream
- Allowed playback of DTS-HD HRA audio passthrough streams via S/PDIF
- Added Uplayer v.0.2.0 as preinstalled application
- Some other system changes
Dumb question. Im looking for the Reset-button on the am8. Google didnt give me anything from my tries. All i can find is Recovery and Maskrom on the back. Is it perhaps Recovery?
Yes, recovery - but why donât you use the Return to LibreElec or Return to CoreELEC apps; much easier than juggling the boxâŚ! ![]()
I am extremely new to this. This is my first elec-box
i just came from shield pro.
So you would have to hold recovery-button Every time you start it? Then the app seems to be a good choice! Thanks
No, only at the first start - then CoreELEC will boot every time you turn it on; although I never turn off my boxesâŚ!
Can you switch from coreelec to âugoosâ with that app? (Or how do you do it if u need to use some normal apps sometimes)
The Reboot to eMMC/NAND option can be found in the CoreELEC menu - and your box will start with AndroidâŚ!
Are people having success with the nightly or with the generic img?
You want this file
Can anyone try to connect the exFAT formatted usb stick to the box? Does it appear for you in the Video/Sources?
@Portisch also on all 4K media that Iâm trying to play Hyperion.ng platform capture is broken. Hereâs a screenshot on how it looks:
Yes, addon must be updated first.
Allrighty, that clears it up
Thanks!
