Please link me with your post so I can check.
I was most interested in seeing if the TV led playback worked or not as thatâs the âpureâ mode anyway ![]()
I donât know if the possibly forthcoming new dovi.ko blob will change things but there clearly seem to be some DoVi issues compared to the S922X at least.
The x96 x10 is on sale on amazon -ÂŁ69.99
$160 in the US ![]()
Yes
Thats what iam saying
How is playback now?
CoreELEC boots by default with Use Player LED
Disabled in settings
So is 8 bit rgb Dolby Vision
If this is what you mean as TV LED ?
When Enable Player LED
It is 12 bit 4.2.2 Dolby Vision
Using iperf I get gigabit speed when receiving from my server and 650 plus Mbps uploading. The start of the movies is really fast, no problem with that. So something with that unit or some weird ethernet problem.
Tested w/Use player led and I get the same crappy DV playback problems.
Yes, âUse Player LEDâ disabled == TV LED and it is tunnelled in 8-bit RGB.
The AV1 version I have of the âDolby Test RPU Not Workingâ clip works on the S928X so itâs something in the HEVC + DoVi combination.
what is a good reason to buy the ugoos am8 pro beside my ugoos am6b+?
At this point, just more power & speed. And, at this point, AM6B+ is the better box for CE.
After being dissatisfied with the lack of a 4K gui on my am6+ Iâve ordered an am8pro.
Now the interface and art work are rendered in 4K and super sharp. Have not touched the am6+ since then.
Thatâs my reason for choosing the am8pro.
Good for you; I donât spend my time staring at GUI, but watching movies/series in DV P7 FEL when available. So, to each his own makes even more sense to meâŚ
haha agreeeeed.
How many movies with âFELâ do you actually have??
Yep the 4K GUI IS the important thing.
The quality of the play of the movies is secondary. ![]()
Btw⌠CoreElec can run in 4KâŚ
Quite a number, I interchange âremuxesâ (along with UHD BD disks) with several friends, and also use streaming from de*rid servers which contain quite a collection ![]()
Ok, I only have very few âFELâ movies. I have both the Ugoos SK1 and AM6B+, but in reality, I really donât NEED the AM6B+.
Hehe, I know that you have a LOT of boxes that you really donât NEED ![]()
