Addiction is a horrible thing. Been purchasing these boxes/sticks for almost 15 years.
Okay
I still do not grasp this TV LED vs Player LED
Argument
Also are you referring to Amlogic Fake TV Led
That was discussed earlier this year in another thread ?
And has carried over with the Amlogic S928X-J SoC
Thats unfortunate (suks)
Maybe go back to the Drawing Board ![]()
Start anew
X96mini.com has official Firmware
They have new releases from August 4th
SDCard OTA Version
And UBT img Version
Update Android
Test CoreELEC on external media
See if have new/ better results
I trust that my (high end) TV knows better how to process the metadata in DoVi, thatâs pretty much the reason I prefer TV led.
zero, none, zilch, nada and of course: ugoos pays/does giveaways to people/organizations who promote it.
Only recently Testing latest Nightly. NE , on X10 PRO 8/64 version.
From your post you have 4/32 working.
In
Settings
System
CoreELEC/Settings
Hardware/Display
There is option to
Dump display EDID
What is this function?
Is there a tutorial/info ?
Is it exclusive to .NE Kernel
@freddy: Does DV content still hang on the X96 X10 PRO?
@Portisch
Will the new S928 devices also get an dtb.img with visible cpu caches?
Currently, it looks like coreelec does not yet recognize the Cortex-A76 completely, but it is used.
CoreELEC:~ # lscpu
Architecture: aarch64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 5
On-line CPU(s) list: 0-4
Vendor ID: ARM
Model name: Cortex-A55
Model: 0
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Stepping: r2p0
CPU(s) scaling MHz: 100%
CPU max MHz: 2016.0000
CPU min MHz: 100.0000
BogoMIPS: 48.00
Flags: fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
Model name: -
Model: 1
Core(s) per socket: 1
Socket(s): 1
Stepping: 0x4
CPU max MHz: 1896.0000
Vulnerabilities:
Itlb multihit: Not affected
L1tf: Not affected
Mds: Not affected
Meltdown: Not affected
Mmio stale data: Not affected
Spec store bypass: Mitigation; Speculative Store Bypass disabled via prctl
Spectre v1: Mitigation; __user pointer sanitization
Spectre v2: Mitigation; CSV2, BHB
Srbds: Not affected
Tsx async abort: Not affected
CoreELEC:~ # lscpu --output-all -e
BOGOMIPS CPU CORE SOCKET CLUSTER NODE BOOK DRAWER CACHE POLARIZATION ADDRESS CONFIGURED ONLINE MHZ SCALMHZ% MAXMHZ MINMHZ MODELNAME
48.00 0 0 0 - - - - - - - - yes 2016.0000 100% 2016.0000 100.0000 Cortex-A55
48.00 1 1 0 - - - - - - - - yes 2016.0000 100% 2016.0000 100.0000 Cortex-A55
48.00 2 2 0 - - - - - - - - yes 2016.0000 100% 2016.0000 100.0000 Cortex-A55
48.00 3 3 0 - - - - - - - - yes 2016.0000 100% 2016.0000 100.0000 Cortex-A55
- 4 0 0 - - - - - - - - yes 1896.0000 100% 1896.0000 100.0000 -
I also noticed that when watching you tube a trailer for a movie, green bars and distortion appeared.
Hello, I bought a x96 x10 pro and I wanted to ask you if you know the vfd file to be able to make the screen work?
Hello, thank you very much for the vfd, now I am looking for the remote.conf but it is not on github either or I cannot find it, can you give me the remote.conf so that the remote works? Iâm using a translator, sorry for the inconvenience
Still canât pass trueHD and DTSHD through TV
Ugoos AM8 â> E-arc TV
Release coreELEC nightly : 2024/10/17
Release Ugoos : 1.3.9
Kodi : 21.1.1
The problem doesnât exist on Android
Is there any intention to fix this issue in the future ? Thanks
Have you checked the audio output settings in Kodi, through System then audio. I had the same issue but I donât have a sound system, it was set to the default settings and I changed it to HDMI multi ch and it worked like a charm.
Iâm having a weird issue here, I canât really connect anything to Bluetooth unless itâs less than a meter away from the box. I tried pairing the UR02 Remote, the Sony WH-1000XM5, and both didnât work.
Is there is any solution to this weird problem?
Thanks for everything youâre doing guys
Make sure antennae is screwed in
I checked all settings and the problem still exists, on android it works perfectly, the problem is only with coreelec
Bluetooth doesnât work for everyone. It seems that the developers havenât had time to fix it yet. Hopefully all the issues will be fixed soon.
For now, the coreelec experience is not comfortable for me and I will continue to use Android until developer support is complete.
Make a debug log while play a short media. Enable kodi debug!
TrueHD and DTS-MA does work fine in passthrough mode on CE.
Android maybe donât use passthrough, they maybe use Multi-PCM.
Thanks for your quick response, I will get back to you soon once it is finished.
Passthrough works with Android and the TV info window shows trueHD.
Did you explicit enable TrueHD passthrough?
No log, no problemâŚ
