Oct 20 07:14:18.484775 CoreELEC dovi-loader[1194]: filename: /storage/dovi.ko
Oct 20 07:14:18.484775 CoreELEC dovi-loader[1194]: description: Amlogic Dolby Vision Driver
Oct 20 07:14:18.484775 CoreELEC dovi-loader[1194]: license: AML
Oct 20 07:14:18.484775 CoreELEC dovi-loader[1194]: vermagic: 5.4.210-android12-9-08157-g5e16466dfeb7-dirty SMP preempt mod_unload modversions aarch64
Oct 20 07:14:18.484775 CoreELEC dovi-loader[1194]: name: dovi
Oct 20 07:14:18.484775 CoreELEC dovi-loader[1194]: depends:
Oct 20 07:14:18.575154 CoreELEC kernel: dovi: disagrees about version of symbol module_layout
Oct 20 07:14:18.575341 CoreELEC kernel: please rebuild ko: dovi
Oct 20 07:14:18.575390 CoreELEC kernel: dovi: module license 'AML' taints kernel.
Oct 20 07:14:18.575436 CoreELEC kernel: Disabling lock debugging due to kernel taint
Oct 20 07:14:18.575477 CoreELEC kernel: dovi: no symbol version for register_dv_functions
Oct 20 07:14:18.579200 CoreELEC kernel: *** amlogic_dolby_vision_init dv: s5 ***
Oct 20 07:14:18.579322 CoreELEC kernel: *** register_dv_multi_stb_functions.***
Oct 20 07:14:18.579368 CoreELEC kernel: Creating DV mp success
Oct 20 07:14:18.579412 CoreELEC kernel: Creating DV mp success
Oct 20 07:14:18.579455 CoreELEC kernel: enable DV HLG when stb v2.6. policy 123
Oct 20 07:14:18.579497 CoreELEC kernel: efuse_mode=0 reg_value = 0x0
Oct 20 07:14:18.579540 CoreELEC kernel: dv capability 7
dovi.ko get loaded and SoC looks support DV.
All your media is Profile 8?
You might share a cut sample as there were issues with P8 in past.
Itās a Profile 5 video, without dovi.ko it plays back with purple and green colors and with dovi.ko again it switches to Dolby Vision on my TV then just a blue screen.
I see same behavior in dmesg here with AM8. With P5 it switch from DV/SDR/DV/SDR/DV⦠until it end up as DV.
On 1080p the Player Process Info show wrong information SDR 444, 8bit but Vertex shows me correct DV-LL 422, 12bit. So this info isnāt ātrustfulā at all.
Does OSD show up on your device or do it stay black while DV is playing?
If itās the X10 4G variant you might return it as we got told āonlyā the X10 8G does support DV. But I would not see now why this should be the caseā¦
Minix confirmed on their forum that the S928X will not support FEL, but convert it. Itāll probably only decode the RPU and convert it to 8.1 like Dune does.
