SoC S5 S928X
Filesystem corruption have nothing to do with DT.
So that case something else is behind my issue.
I’ve only seen on other models that e.g. eMMC speed, front LED behavior and other similar things can be adjusted in the CoreELEC add-on, and these things are based on the dtb file.
Otherwise, would it be possible to create a dtb file for CoreELEC? I think this is essential for OpenVFD support.
Thank you.
how is the P7 FEL status on the ugoos am8? any progress?
Nobody working on that.
It“s not possible - no dovi with FEL support available
Hi everyone,
I’m running into a strange issue with Dolby Vision playback on my setup and was hoping someone could help or provide some insight.
Setup:
Device: SK1
CoreELEC: Omega (stable) 21.2 coreelec-ne
TV: Dolby Vision compatible
Refresh rate switching: Enabled
Issue:
When the initial refresh rate is set to 120Hz, Dolby Vision does not get triggered when I start a Dolby Vision file. Instead, the video plays with green/purple tint, clearly indicating something is off. However, if I set the initial refresh rate to 60Hz, the same Dolby Vision file plays perfectly, and DV is correctly triggered on the TV.
In both cases, the refresh rate changes when the video starts (as expected), but the behavior is different depending on what the initial refresh rate was set to.
Has anyone else experienced this? Is this a known issue with 120Hz modes or something specific to the SK1 box?
I have tried the latest nightly as well
Logs
https://paste.coreelec.org/CleanersSatyr
Use CE-NO and 120Hz are not supported.
Got it, thanks
Is there any indication of support for S928X-K/J upcoming?
s928x has been supported for a year
I don’t see it in the download list?
You can use Generic img. software for devices with 928X -K-J processors.
I don’t see a generic S928X download list in the drop-down, only 950?
Can you point me to the correct page? I’m looking in https://coreelec.org/ Downloads 21.2 Omega.
https://relkai.coreelec.org/Amlogic-ne/ce-21/CoreELEC-Amlogic-ne.aarch64-21.2-Omega_nightly_20250606-Generic.img.gz
Here you can download the version you want.
You can download the stable version here.
Thanks for that, not exactly obvious to a newb on this forum, appreciated. I don’t suppose you could point me in the right direction for newb install support? thanks. :slight_smile:
You can use here for installation
https://wiki.coreelec.org/
Thanks again
Better use CE22-no, even though it is not officially in a stable phase, it practically is. CE21-ne is not being developed anymore.
Hi, I have X96 X10 Pro 8GB too, and I installed ne ce21 nightly. But now the factory remote can’t work, I have opened bluetooth and connected remote, but no action press any key. Is there any step I missed?
This is the guide I follow : [Guide] S928X-J CoreELEC installation and FAQs
I just don’t enjoy the Dune HD 8k GUI much at all. I don’t have any android apps and I just prefer CE zooming around on the internal than off a USB.
Willing to try it but concerned about bricking the Dune.
Ah when they moved the post it lost the title which was: Has anyone tried to install CE on Dune HD Pro Plus 8K emmc?
