I’m reading many pages about this issues.
I’m using s912 h96 pro+ 3/32 device, running coreelec 8.95.7 release with Kodi v18 Leia (Release Candidate 4), a samsung Q9F tv (4k) via receiver (direct passthrough video).
For some reason I can’f figure out how to set the best videosettings so that:
- 1080p movies are sent to tv as 1080P and TV will upscale them, instead of upscale 1080p-4k on s912.
- 4k movies, are sent direct as 4K on tv.
I’ve put Kodi gui into 1080p, but for some reason i can’t find out, 4k is sent to tv as 1080p.
I’ve tried to change settings like Adjust display refresh rate/ Sync playback to display but but no luck yet.
is there a “simple” guide how to set this combination, so the TV will do all the upscaling, while mediabox will send it as direct to the tv? I want this because when box is doing the upscale, i see somethings slight issues in movies, which i didn’t see when i had just a 1080p tv. (off course then no 4K).
